Author Topic: 15x7 phone dials on a bug?  (Read 9299 times)
Offline somevwguy
  • Jeff
    • strictlygerman.ca
« on: November 15, 2009, 05:15:28 PM »
So I have a set of 15x7 phone dials, with a 23 offset.  The car is a 66 bug on a 68 irs/bj pan.  Will a 2" narrowed beam, re-drilled rotors be enough to get the phone dials under the front fenders?  Or if I found 2 15x6 with 23 offset would they work with the stock beam?  In the rear will I be able to use adaptors or will I have to get re-drilled drums.  Thanks for the help, Jeff
Re: 15x7 phone dials on a bug?
« Reply #1 on: November 16, 2009, 12:13:58 AM »
With a 2" beam, you need the 6" wheels, depending on what tires you want to use. ??
For the rears, get some 68+ up rear drums and redrill them for P pattern and stud them.  Better yet, get some Type 3 drums.  The 7s will fit with early short axles with ease.
Offline somevwguy
  • Jeff
    • strictlygerman.ca
« Reply #2 on: November 16, 2009, 10:09:53 PM »
Cool, so the rear go for re drilled drums.
In the front, would I even need a 2" narrowed beam with 6x15 with a 52mm offset?  If I bought a set of 6x15 with the 52mm offset could I get away with only buying the re-drilled disks?  Am i right in thinking that the 52mm offset will sit 25mm closer to the car/beam/inside than the 23mm offset?  I'm trying to figure this offset stuff out, Thanks for the help, jeff
« Reply #3 on: November 16, 2009, 11:10:13 PM »
Is the ET of your wheels 52mm or 23mm?
What tires are you planning to use?
Offline somevwguy
  • Jeff
    • strictlygerman.ca
« Reply #4 on: November 17, 2009, 09:44:08 AM »
The wheels i have now are 23mm, but if I'm going to buy 6x15s then i want to buy wheels that have the best offset for me.  I was thinking of running 195/50 up front.
« Reply #5 on: November 17, 2009, 07:05:43 PM »
If you use the 6s with ET23, you will need to chop the beam more than 2".
If you use the 6s with ET52, not only will you not need a narrowed beam, you will likely need a wheel spacer!  I think 3/8" may do the trick.  A set of dropped spindles may be necessary too.
