Air Speed Lounge
dp engine codes
Topic: dp engine codes (Read 1184 times)
beetlemandan
dp engine codes
November 14, 2009, 12:37:43 PM »
i got a few dp blocks coming my way, what are the best ones to keep? a questionable source gave me a little doubt, so are AK, AE and AH blocks all about the same alloy?is there one i should avoid boring for bigger cylinders?
the customer is always wrong
Bruce
Re: dp engine codes
November 14, 2009, 11:53:40 PM »
The AK and AH cases are exactly the same. They are the latest design, with 8mm threaded inserts for the headstuds. The AE case is also exactly the same, but without the head stud inserts. To use that one is just a bit extra work to put the inserts in.
beetlemandan
Re: dp engine codes
November 15, 2009, 10:53:11 AM »
thanks!
Air Speed Lounge
dp engine codes
