Author Topic: 16" phone dials on 66 bug?  (Read 4426 times)
Offline somevwguy
  • Jeff
    • strictlygerman.ca
« on: September 20, 2009, 10:18:44 AM »
I've found a set of16" x 7" Porsche 928 phone dials with 65mm offset.  I'm wondering what it would take to fit them on a 66 bug (with a 68 IRS/BJ pan).  I'm thinking re-drilled drums in the back, and 3" narrowed beam, ghia disks and adapters in the front.  I want to run stock fenders all the way around if possible.  Thanks for the help.
Re: 16" phone dials on 66 bug?
« Reply #1 on: September 20, 2009, 02:04:43 PM »
Hopefully you have 68+ long axles and 4 lug drums, or it's a 68 autostick pan with a 4 speed??  If so, you could redrill the drums, but you're going to need a really thick spacer.  Because of that, an adapter works for you.
At the front, do not waste your time with a narrowed beam.  Not only are you not going to need that, you're going to need wheel spacers too.
If you want to check things before you spend the $, do the disc conversion and bolt the bare wheel onto the drums and rotors to see where it lands compared to the outer fender edge.
Offline somevwguy
  • Jeff
    • strictlygerman.ca
« Reply #2 on: September 20, 2009, 05:41:50 PM »
cool, I haven
