Author Topic: Help me through my first engine build  (Read 13568 times)
Offline 85fastlane
« on: September 01, 2009, 10:55:23 PM »
I'm just starting on my first build. I've read over the Wilson manual several times and have a good understanding of every aspect I think. I'm pretty comfortable with it, and it's just a stock 1600 so nothing gets too complicated. I just might have a couple questions along the way. My first one is what oil pump to use. The case is an AS41 with a 211 (Bus) number on it. From everything I've read it would need to run a dish cam gear and the deeper oil pump in this case. The only reason I have confusion over this is that when I dissasembled the engine it had a flat cam gear in it. Do I need to pickup a cam with a dished gear and fit the later pump? I picked up the engine as a non-running spare, so I have no idea if the previously installed setup worked well or if it had problems. This will be for a T3 application when finished, not that it makes any difference for this question. Thanks in advance for your help!
Cheers,
Lane
Offline 85fastlane
Re: Help me through my first engine build
« Reply #1 on: September 02, 2009, 12:11:30 PM »
Ok, AVR helped me out with this one. Apparently there's an oil pump that is the shallower style to go with the flat cam gear, but also has the large 10 mm oil passages, kind of a half early, half late design. Next question, I'm not interested in throwing a ton of money at fancy new tools right now, what's the cheapest way to set up some sort of end play measuring tool?
« Reply #2 on: September 02, 2009, 12:40:09 PM »
use a paper clip with a 3.24" long pc of thread. Then take that to princess auto and buy the damn tool then eat the clip and thread :)..... hope that helps dood O0
Offline 85fastlane
« Reply #3 on: September 03, 2009, 12:18:16 AM »
You're a peach
« Reply #4 on: September 03, 2009, 08:53:26 PM »
...what's the cheapest way to set up some sort of end play measuring tool?
dial indicator with a magnetic base.
or....
http://www.jbugs.com/store/merchant.mvc?Screen=PROD&Product_Code=5760&Category_Code=Tools
(maybe AVR has one of the above mentioned items).
or you could probably make something like the above with some bolts, nuts & steel.
« Reply #5 on: September 03, 2009, 10:45:45 PM »
I made a similar tool using only a short length of threaded rod and some big washers and nuts.  Adjust it so that the washers are almost right on the flywheel, then use feeler gauges.
Offline 85fastlane
« Reply #6 on: September 03, 2009, 11:20:39 PM »
Thanks for the help guys, things are going well. Case is all buttoned up and flywheel on. I'll put on the pistons and pots tomorrow, hopefully have my heads finished at the machine shop, should have the engine back in the car Saturday. Any tips on first start up besides cranking without ignition for oil pressure. Follow the Wilson? 20 minute at 2000 rpm idle, then go for a drive for 20 or 40 miles accelerating and slowing constantly? Change oil, adjust valves at that point, and then good to go?
Offline 85fastlane
« Reply #7 on: September 18, 2009, 05:43:53 PM »
Finally back at it after a tumultuous couple of weeks. I picked up my heads today from FVE&M and wow, they look incredible, better than I ever thought they could look. So I might bolt them on tonight. Just had a question. I'm going to use a set of swivel foot, ball type adjuster rockers that I had. What lash do you set these at with OE pushrods?
« Reply #8 on: September 18, 2009, 09:18:14 PM »
With Al pushrods you set the lash to the stock spec.  0.15mm
Offline 85fastlane
« Reply #9 on: September 18, 2009, 11:43:28 PM »
I thought I heard at some point that with the swivels they didn't need lash, they could be set to soft 0? Can anyone clarify? Does it matter that I switched up rockers?
« Reply #10 on: September 19, 2009, 07:23:27 AM »
Not with OE pushrods, ~0 is only for chromoly pr's. Lifters don't make a difference.
Offline 85fastlane
« Reply #11 on: September 19, 2009, 09:24:48 AM »
Gotcha, thanks much! We'll see once it's all together what the rocker geometry looks like. A mockup of it looks not bad, but we'll see when it's all in place.
Offline 85fastlane
« Reply #12 on: September 22, 2009, 12:41:48 AM »
Oh how very frustrating. Tonight I went to bolt on the heads, and just as I was torquing on the very last head stud I noticed it was just pulling straight out of the case. It was holding a snug hand tight but as soon as I gave it the initial 15 ft/lbs it let go. So heads are coming off, piston and cylinders are coming back off. I'm also assuming there is no way to tap it without splitting the case again? I'm sure you'd get all kinds of nasty filings inside. This has 10mm studs, no savers. I guess I'm tearing it completely apart and resending the case to the machine shop for case savers now? Guess I shoulda went for it from the beginning. If there's any quicker, less painful way to fix this please let me know!  :-[
« Reply #13 on: September 22, 2009, 08:13:32 AM »
DOOD!!!!!!!!! Did you have beer?????
Offline 85fastlane
« Reply #14 on: September 22, 2009, 09:21:58 AM »
I know I know, next time through assembling I'll make sure there is a steady supply of beer so that everything goes smoothly! Oh well, this time I guess I can really take my time, maybe do a couple things I skipped over last time, since I think I'll be parking it now for the winter.
Offline GMB
« Reply #15 on: October 05, 2009, 12:53:56 PM »
There is such a thing as a self tapping stud in the long length for the bottom studs and medium length for the top outers. It's not ideal but in this situation will get you on your way. I have used them before and properly installed will outlast the origionals.
    Gary.
Warrior sand rail:
2276cc 82x94
Single 40mm Kadron w/32vent
Equalizer 5lb pulley
Stock lifters
Stock aluminum pushrods
Offline 85fastlane
« Reply #16 on: February 20, 2010, 08:51:30 PM »
Thanks for the tip. Tonight it finally came together after a long absence. With Cheech's extra hands for install we had her running in no time. No exhaust yet though, so a little loud for driving, but so so very stoked to hear my first build fire up and run smooth. Very cool! Pics soon, maybe video too!
Bexsladadia
« Reply #17 on: July 07, 2010, 10:35:33 AM »
Thanks for the info.  Ill look you up when I get to that point of the build.
Anyone else with ideas/comments?
Jake
Offline 85fastlane
« Reply #18 on: July 07, 2010, 01:41:22 PM »
5000 miles and counting. Needs carbs rebuilt now though.
