Author Topic: no spark  (Read 4837 times)
Offline 696969vw
no spark
« on: May 09, 2009, 07:22:46 AM »
I have a 1600 dp, was running, now it turns over but no spark from the coil. The coil has power from the ignition when the key is turned on. I have changed the coil - still no starty! :'( Any thoughts?
Mark
Re: no spark
« Reply #1 on: May 09, 2009, 08:13:38 AM »
You have a stock distributor?
The points are good and calibrated?
Check spark plug cables, coil, points (condensor?)
Maybe take a good look and see if your cap and rotor are good and you reinstalled them correct after looking for the problem.
« Last Edit: May 09, 2009, 08:28:43 AM by egspot »
Re: no spark
« Reply #2 on: May 09, 2009, 08:26:27 AM »
Check spark plug cables, coil, points (dondensor?)
I had a bad dondensor once. Check yours. O0
Offline 696969vw
Re: no spark
« Reply #3 on: May 09, 2009, 12:08:21 PM »
a Bad condensor thanks. Running fine now.   :)
Mark
