Author Topic: what would macguyver do??  (Read 2577 times)
« on: May 03, 2009, 06:21:18 PM »
the car is running like a champ and you're cruising along at a good pace and all of a sudden the car dies. 5 minutes of diagnosis reveal that the fuel pump has called it quits. 15 minutes of cursing reveals that you have absolutely no extra fuel pump parts on board (except for about 1 foot of hose...and it's not your sae approved fuel hose).
you're on the narrow shoulder of a small 2 lane mountain road out in the middle of knowhere on highway 24 (point A on map below)....37 kms west of little fort (point B on map below...the closest town with not much of anything going for it....classic car parts wise) and you have little to no cell phone signal.
http://maps.google.com/maps?f=d&source=s_d&saddr=51.488224,-120.565338&daddr=little+fort,+british+columbia,+canada&hl=en&geocode=&mra=dme&mrcr=0&mrsp=0&sz=11&sll=51.471974,-120.362091&sspn=0.290843,0.668793&ie=UTF8&ll=51.476251,-120.08606&spn=1.163273,2.675171&z=9
what would you do???
let's have a good 'ole fashioned brain storming session!!!
(no hints from the frose family or dave please...you guys know the outcome of this one ;))
« Last Edit: May 03, 2009, 06:23:07 PM by silas »
Re: what would macguyver do??
« Reply #1 on: May 03, 2009, 07:11:15 PM »
NO I Don't.
Sow how did you get it going??????Did you use some compound to rebuild the diafram? Did you buy an electric pump?
What - Up?
« Reply #2 on: May 03, 2009, 07:29:32 PM »
turn it around and push it back down the map....
« Reply #3 on: May 03, 2009, 08:44:48 PM »
I can relate Silas. I cant remember how many times I have been on the side of the I-5 when my generator or fuel pump has called it quits. Now you know why I have a car trailer. ;)
Billyisgr8
« Reply #4 on: May 03, 2009, 08:49:35 PM »
siphon gas out or drain it from the fuel tank and keep filling up the carb fuel bowl manually.
Offline el_flechador
« Reply #5 on: May 03, 2009, 09:13:12 PM »
use the windscreen washer pump( if you have the electric type) and keep filling up the resevoir  O0
If i win a pony i want a pink one
« Last Edit: May 03, 2009, 09:15:28 PM by el_flechador »
« Reply #6 on: May 03, 2009, 09:48:53 PM »
gravity feed from a gas can?
« Reply #7 on: May 04, 2009, 07:39:16 AM »
We had the same problem leaving Seattle many years ago, we gravity fed the  carb from a gas can in the rear seat with the hose going out the rear pop out....got us home ;D
« Reply #8 on: May 04, 2009, 10:16:03 PM »
Quote from: GRK
you nailed it!!!
Quote from: Geoff
i was thinking about the gas can in the back seat & popout window scenario the day after the break-down and thought it could have worked better (read safer) than what we had going on.
however....at the time of the break down we had no gas can and a very limited amount of hose.
so here's what happened. bear with me...this story may take awhile!
first of all...some very friendly locals pulled over and really went out of there way to help us out. they had better cell phone reception than us and were able to get a message on daves cell describing the predicament. they also provided some white hose (1/2" od...the plumbing kind!!) and were very friendly and helpfull when it came time to rig this system up. they even drove to little fort and got us an electric fuel pump that we were very close to plumbing and wiring so we could continue on.
secondly...a very kind hearted man by the name of carl (mr sweep) was driving the sweep vehicle (follows the rally making sure everyone is getting along ok) and was a huge help aswell by running to meet dave (who was kind enough to drive all the way from sunpeaks with a good used fuel pump) in barriere aswell as helping out with tie-downs, encouragement and following us down the highway making sure everything was allright.
disclaimer---the events described below were done in an act of desperation and should not be used as common practice. it's not the safest/smartest way to do things...but it got us off the side of a mountainous road in the middle of butt-f@#k nowhere...and into the town of butt-f@#k nowhere!! ;D ;)
so when it was down & dirty on the side of the road with no gas can and a foot of vacuum line for hose, the locals pulled over and made a call to dave (who then called mr sweep) and provided us with the white hose and a 500ml water bottle. one of the locals was a heavy duty mechanic and also had some great ideas and some good connections for parts in little fort...and a flat deck if we needed it!!! we filled the water bottle with gas and cut a hole in the lid just big enough for the vacuum hose. we then put the vacuum hose in the bottle, stuffed the white hose (1/2" od plumbing hose from the locals) onto the vacuum hose (with electrical tape & a hose clamp for safety of course :o) and the stuffed the fuel line from the carb into the end of the white hose (with electrical tape & a hose clamp for safety of course  :P). we zap strapped the 500ml water bottle to the louvers in the decklid (length of hose was preventing us for any other mounting place) and got the feed started and motored down the highway for a bit.....
until the bottle was empty....which luckily just happened to occur on a gradual uphill left hand corner!!!
so fill up the bottle and get a little further down the road....at which point mr sweep caught up with us!!! and he had a gerry can!!
the locals had been following us this whole time, and we made the decision for them to go to town and get the electrical fuel pump (because at this time we didnt know that dave had got our message or what other kind of extra fuel pump parts we would have at our disposal) and mr sweep and myself ditched the 500ml auxilary gas tank for the gas can kind (more fuel = longer distance traveled)!!
so we got our tie downs and hooked them through the louvers and secured the gas can to the back of the car the best we could. again, the back seat would have been best, but the more i think of it, the more i think that our biggest restriction was the length of our home-made fuel line.
so after smoking the front shoes on the a huge downhill about 5kms out of little fort...the car cuts out again. the homemade hose is no reaching far enough into the can and picking up any fuel.
at that exact time mr sweep heard from dave, so lori & i decided to hang out on the side of the road while mr sweep took off to meet dave and bring him back to us with some fuel pump parts.
but i wasnt content with just sitting there so i reconfigured the gas can & hose so we could get some more feed, got the car going, and limped it into little fort.
just as we pulled into little fort is when the locals returned with the electrical fuel pump. and allthough i was very thankfull that the locals had been such a big help and had found an electric pump for us...i was kind of fighting the urge of mounting, plumbing and wiring the pump to the car. but i still really wasnt 100% sure what kind of parts dave had and if they would work...so i was really torn as to what to do. ideally, dave would have parts that were oem and would work....as a back-up we had an electric pump that was ready to go.
so mr sweep & dave return, we find out dave has a complete pump (taken out of russels super on the side of the duffy lake road as he replaced it with a new one from the frose's...see pic in the gallery) and within 15 minutes we had the thing in and the car was running!!! eureka!!!
i whole-heartedly need to thank carl (mr sweep) & dave and joe & bonnie (the locals) for all their help.
joe & bonnie were the kindest, most helpfull people that we could have met. they went way out of their way to help us out and lori & i really had a chance to bond and get to know them through this whole escapade. their whole perception of the way things should be is "pay it forward". which is the way lori & i like to live our lives too. do good things for people while not looking for anything in return and naturally good things will happen to you. and it is very apparent that mr sweep & dave are the same way. i insisted that i needed to give these people something for all their help. but no amount of persuasion would work, and none of them wanted anything in return. dave gave joe & bonnie some spring thaw merch and lori & i thanked them profusely and gave them a good hug and a handshake...and that was all they wanted.
after alot of arm twisting and arguing ( ;)), mr sweep & dave agreed to let lori & i treat them to dinner and a few beverages and that is all they would allow us to do for them.
also, big thanks to the frose's for supplying russell with a fuel pump and russell for supplying me with his old fuel pump. plus the old guy in the mini that had some extra fuel line for me when i found leaky line the next day. i'll get you all back somehow. good things are coming your way!!
and so the story goes...it's why we're all in this big mess together. pay it forward folks!!!
 8)
« Reply #9 on: May 04, 2009, 10:24:38 PM »
oh yeah...unfortunatley...our camera had failed shortly before this so we didnt have a chance to get a pic of the rig. but we're pretty sure mr sweep got one and if it is found and useable...it will be posted!!!
also, after this whole fiasco we were presented with the "2009 spring thaw classic car adventure macguyver award"...allthough it was a very marginal win considering we were up against this guy in the saab who installed his blown out spark plug with electrical tape....
http://www.flickr.com/photos/formulaphoto/3495540299/in/set-72157617584735336/
 8)
Offline Chris W
  • Portland Oregon
« Reply #10 on: May 05, 2009, 08:39:42 AM »
Macguyver would have made a hang glider out of balsa wood and jungle twine and flown home. I guess what you did was ok  ;)
« Reply #11 on: May 05, 2009, 08:50:46 AM »
Way to go good story nice pics and looks like all things aside a great road trip  8)
« Reply #12 on: May 05, 2009, 09:09:05 AM »
Great story with a great ending. ;D
NOTE TO SELF.......pack an extra fuel pump too.
« Reply #13 on: May 08, 2009, 02:43:53 PM »
 ;D
the rig....
the fix...
left to right is dave hord (one of the spring thaw organizers/asf member/69 beetle), me, lori (my girlfriend), and bonnie & joe (our helpfull & friendly locals).
photos courtesy of mr sweep (carl clarkstone).
