Author Topic: engine noise.  (Read 10812 times)
engine noise.
« on: February 12, 2009, 03:58:38 PM »
Ok so I have not been driving the bug as much and I start it every second/third day and take it around for a mile or two and park it.
Last week it stated making a noise and i figure the valves needed adjustment. I have not done a valve adjustment other than verifying the gap in over 27 years. I searched the web and found this instructions:
It is no secret that if you want your Volkswagen's motor to last more than five or ten thousand miles between overhauls, you have to change the oil and adjust the valves. Changing the oil is easy, provided you have someplace to dispose of the waste oil (Hint: Don't pour it down a drain or dump it out on the ground. Find a garage or service station that recycles its oil and leave it with them.
Adjusting the valves is a little more work, but it is no less important. As your motor runs, the heat and the force of the valve spring pulling the valve closed can stretch the valve stem, making the valve longer. After enough stretching, the small amount of clearance between the adjustment screw in the rocker arm and the end of the valve will disappear. When this happens, the adjustment screw will begin to hold the valve open a little instead of letting it close fully, not allowing a good seal between the valve and the valve seat, so you lose power. Even if that were the only result of having tight valves, it would be bad enough. Unfortunately, there is another reason why the valve face must seat firmly against the valve seat.
Inside the combustion chamber, there is a lot of heat created by the burning gasoline. Some of this heat soaks into the head of the valve. The valve has only three ways to disperse this heat: cooling due to the intake charge, heat dissipation through the valve stem and heat dissipation through the valve seat.
Racers and other high-performance enthusiasts can use what is called "charge cooling"to help keep the valves alive, but unless you are an expert at this sort of thing, you can pretty much write off charge cooling as the answer to your hopes for a cool running engine.
That leaves heat dissipation through the valve stem and seat. Valve stem heat dissipation is pretty much a function of the valve stem diameter and the condition of the valve guide. This is on the reasons why it is so important to have good, right valve guides.
With the scrawny, little valve stem you find on a Volkswagen valve, however, it is clear that a lot of the cooling has to come from planting the valve face on the valve seat long enough and firmly enough to allow heat to transfer from the valve head to the cylinder head.
Now that you understand all of that, it's time to start thinking about adjusting your valves. You are going to need some valve cover gaskets, a 13mm wrench, a screwdriver and a feeler gauge. Check your owner's manual (or a Bentley manual) to find out what thickness feeler gauge you should be using. If you have neither of these sources, get a 0.006-inch feeler gauge to start out with stock engines (some experts recommend setting valves at 0.004 inch, but to start with 0.006 is fine--it gives you some margin of error until you get good at this.) It helps if you are able to get your car up in the air a little with a set of jackstands or a hoist. Open the engine cover and manually turn the motor until it is at Top Dead Center (TDC). IT doesn't matter whether piston one or piston three is on the compression stroke, just find TDC.
Now, slide under the car and pull off the valve covers. If your hands aren't strong enough to do the trick, wrap a shop rag around the valve cover bail, grab the two ends of the rag and pull outward and downward sharply. The bail should snap off. Depending upon how long the valve cover has been on (and how hot the car has been), you might have to pry the valve cover away from the head with a screwdriver. Place the valve covers on the ground so that they catch any dripping oil.
It should be pointed out that Volkswagen valves are adjusted with the engine cold. You can't drive home from work, pop the covers and do a "quickie"adjust, then speed off for the evening. The motor must sit long enough so that it is cool to the touch. It might not be very convenient, but at least you won't be burning your hands on this job.
As you look up into the engine, you can see there are four valves on each side of the engine...eight in all. Reach up and manually check for clearance of the four closest to you. You should find that there are two "patterns"to which valves have clearances and which valves don't. Either the front three valves will have clearance (and the back valve will be tight) or the back valve will have clearance (and the front three will be tight). I say "should" because if you have a valve that has lost all of its clearance, it won't be loose under any condition, but that's the situation we're trying to prevent, right?
Insert your feeler gauge between the end of the valve stem and the end of the valve adjustment screw. If you have never done this before, give yourself some time to get used to the way the feeler gauge feels. The gauge has to be held "just right" in the gap. If you twist or pull on the feeler gauge you will get an erroneous feel for what the gap is.
You are looking for the feeler gauge to slip between the valve stem and the valve adjustment screw with a little resistance. If the feeler gauge falls out when you release it, the gap is too large. If you have to force the gauge in and then strong-arm it out, the gap is too small.
Let's assume that by this point you have determined that the gap isn't right. Take the 13mm wrench and loosen the jam nut on the valve adjustment bolt for the improperly gapped valve. Use the screwdriver to change the gap while you monitor your progress with the feeler gauge. If you want to get really trick, many retailers offer a combination wrench and screwdriver just for adjusting your valves. Be careful that you don't clamp down on the blade of the feeler gauge while you are tightening up the adjustment because you will deform the gauge material and it will be more difficult to get a good feel for the gap.
When the gap feels right, hold the adjustment screw with the screwdriver and use the 13mm wrench to tighten up the jam nut.
Murphy's Law states that if the gap feels perfect, the adjustment screw will try to turn when you tighten the jam nut. That's what the screwdriver is there for. It might take a couple of tries, but don't panic. Make certain to double check the clearance after you tighten down the jam nut.
Repeat this procedure with the other three valves. You are now half done. Go up topside again and rotate the engine 360 degrees until the TDC mark comes up. Scrunch under the car again and check the clearance pattern. You will see that it has reversed itself from side to side. The three that had no clearance on one side now have clearance and the one valve with no clearance on the other side now has clearance as well. You can now adjust the remaining four valves as you adjusted the first four.
It all sounds pretty rosy in print, but there are things that can come up. If the rocker arm isn't bolted down tight, your adjustments will be off. There is a far more common problem, however, and it can be pretty aggravating. You insert the feeler gauge into the gap and notice that there is too much clearance. You turn the adjustment screw a small fraction of a turn and suddenly there is no clearance. And no matter how long you fool with it there isn't any middle ground; the adjustment is either too loose or too tight.
Here's what's happening: The ends of the adjustment screws have developed little flat spots from misadjustments, oil breakdown or just plain age. The cure is to pick up a new set of adjusters. They normally come with jam nuts, which is good because they can get pretty rounded off. Replace the old adjusters with the new adjusters and life should once again be a bowl of cherries for you.
Clean out the valve covers and replace the old valve cover gaskets with the new gaskets you bought. You do not need glue to keep the gaskets in place. Put the covers back on and snap the bail wires in place. Let the car off of the stands and check your oil lever.
By checking your valve adjustment every 2,500 to 3,000 miles when you change your oil, you will help ensure that you will never fall prey to a burnt valve.
Where I live I am discouraged from working on the car too much so, I took a vacation day and waited until most were gone to work.
I did it and checked it twice and the noise remains.
Now I am thinking (WOW) maybe it is an exhaust gasket that is leaking as it sounds like a fart that sneaks out (you all know that noise.)
Other than that I would think that one of my heads is coming loose.
Anyone has anything positive that i could go to school on? ???
« Last Edit: February 12, 2009, 04:45:57 PM by egspot »
Re: engine noise.
« Reply #1 on: February 12, 2009, 10:22:52 PM »
okay....
so when does the fart sneak out? at idle? at what rpm? under load? all the time? sometimes? when cold? when hot?
and how does the fart resonate? one constant tone? does the volume change? is it a consistent "blatt-blatt-blatt" or does it miss a beat every once & awhile?
Re: engine noise.
« Reply #2 on: February 12, 2009, 10:37:13 PM »
okay....
You are funny man.
I am realy hope that it is a small exhaust gasket leak. I will change th e whole exhaust system if I have to tomorrow. I only hope that I dont have to re-torque the heads.
Thanks man.
Re: engine noise.
« Reply #3 on: February 12, 2009, 11:27:11 PM »
okay....
You are funny man.
Thanks man.
i was serious.
if you really think it's an exhaust leak, get under there and look at all flanges/joints/pipe connections in the exhaust system and look for the presence of black sooty substance. then start the car and carefully run your hand around the exhaust (no touching) & feel for a leak (pulsing air)...carefull...it'll be hot.
Offline dods1600
Re: engine noise.
« Reply #4 on: February 13, 2009, 01:09:03 PM »
I agree with Silas, my car was making the same noise and it turned out to be a small exhaust leak coming from the flange.
I drive a fat chick
-Tristan
Re: engine noise.
« Reply #5 on: February 13, 2009, 03:57:07 PM »
Put a rag or rags over however many outlets your particluar system has and listen, the noise will get louder if it's a leak, if it's something else it'll be easier to hear.
Re: engine noise.
« Reply #6 on: February 13, 2009, 06:27:18 PM »
My Golf got hit today (fender bender) by a guy who turn righ at a red light. I will need to drive the bug when the Golf goes for repairs.
I went downstairs with gaskets, merger, and hideaway muffler . I was prepared to tear it apart. I was like a Tim the Toolman Taylor ready to tackle the job.. :D
Well, with wrech in hand I hit the ground and proceded to remove the heaters. BINGO, there was a nut missing on the top (no signs of black on the gasket or anything.) It is one of the worse nuts to deal with on this business. I fixed it and checked all the other ones.
I got lucky and go my valves adjusted as a bonus. ^-^
Thanks for all the replies guys.
« Last Edit: February 13, 2009, 10:11:57 PM by egspot »
Re: engine noise.
« Reply #7 on: February 14, 2009, 12:18:59 AM »
Good for another 27 years!
Re: engine noise.
« Reply #8 on: February 14, 2009, 07:31:53 PM »
okay...i didnt read this whole blurb until just now...
...Open the engine cover and manually turn the motor until it is at Top Dead Center (TDC). IT doesn't matter whether piston one or piston three is on the compression stroke, just find TDC...Now, slide under the car and pull off the valve covers...As you look up into the engine, you can see there are four valves on each side of the engine...eight in all. Reach up and manually check for clearance of the four closest to you. You should find that there are two "patterns"to which valves have clearances and which valves don't. Either the front three valves will have clearance (and the back valve will be tight) or the back valve will have clearance (and the front three will be tight). I say "should" because if you have a valve that has lost all of its clearance, it won't be loose under any condition, but that's the situation we're trying to prevent, right?
Repeat this procedure with the other three valves. You are now half done. Go up topside again and rotate the engine 360 degrees until the TDC mark comes up. Scrunch under the car again and check the clearance pattern. You will see that it has reversed itself from side to side. The three that had no clearance on one side now have clearance and the one valve with no clearance on the other side now has clearance as well. You can now adjust the remaining four valves as you adjusted the first four...
am i missing something here or is this actually the worst description and wrong way to adjust your valves? i've never heard of the old rotate the engine twice and do the whole side at .006" all at once routine?
imho, if anyone has ever adjusted their valves this way...they should stop driving immediately and go and re-adjust the right way.
glad you found the exhaust fix emilio!!
« Last Edit: February 14, 2009, 07:33:47 PM by silas »
Re: engine noise.
« Reply #9 on: February 14, 2009, 08:15:28 PM »
Re: engine noise.
« Reply #10 on: February 14, 2009, 11:21:52 PM »
You're right Silas, it is a really dumb way to do it.  Much more complicated, and prone to missing some valves.
Even dumber than that is this:
"Insert your feeler gauge between the end of the valve stem and the end of the valve adjustment screw. If you have never done this before, give yourself some time to get used to the way the feeler gauge feels. The gauge has to be held "just right" in the gap. If you twist or pull on the feeler gauge you will get an erroneous feel for what the gap is.
You are looking for the feeler gauge to slip between the valve stem and the valve adjustment screw with a little resistance. If the feeler gauge falls out when you release it, the gap is too large. If you have to force the gauge in and then strong-arm it out, the gap is too small."
What a load of crap!  This was obviously written by some mechanic that wants you to think only he has the special feel to do the job right.  How stupid!  The easy way for the novice to set the gap way more accurately than the pro that follows that method is to use a .006" feeler gauge to set the gap, then to check it with a .007" gauge afterwards.  If the 6 goes, and the 7 doesn't, you are done.
Re: engine noise.
« Reply #11 on: February 15, 2009, 10:15:25 AM »
You mean he was special? VW Trend ??? I have to agree that this is very condescending to anyone who will dare to try rocket science by adjusting his own valves.
I usually refer to  my book for idiots but since my storage got moisture, all my closets are foll on car parts and my books are buried. So i went to the web. I found that at TDC one is tight and the others are loose on one side and the opposite on the other side. They reverse once you turn 360. As far as the gap I was somewhat anal and I checked them over and over. The engine sound good now and as it turn out only one fuel valve on #1 needed a small adjustment to close the gap.
Re: engine noise.
« Reply #12 on: February 15, 2009, 03:48:44 PM »
http://www.vwtrendsweb.com/tech/0106vwt_valve_adjustment/
figures...just another reason why vwtrends is no longer in print and on the stands. no one is willing to pay for that jargon. the author seems like he's trying to re-invent the wheel for no good reason. i have read alot of acvw manuals and read alot of repair procedures on the www and i have never, ever seen a valve adjustment procedure run like that. it just seems ass backwards to me.
Quote from: egspot
hey emilio...bookmark/save as favourite/never loose this link...
http://www.vw-resource.com/mihov_index.html
it's like the john muir idiots guide but online...it's not gospel but it's an easy read.
nothing beats a bentley tho...well worth the cash!!!
Re: engine noise.
« Reply #13 on: February 15, 2009, 05:28:44 PM »
Thanks Silas.
Cool site. :-[
