Author Topic: lowering rear suspention  (Read 3432 times)
Offline Dan
  • Crown Royal straight up....Thanks
« on: January 11, 2009, 08:01:48 AM »
Previous owner cranked rear suspention up too the max on a bugy chassis I'm working on.Anyone ever reset the IRS on one that could give me some pointers before I try it myself.Or should this be better done at an alignment shop.
We are Bigfun
Re: lowering rear suspention
« Reply #1 on: January 11, 2009, 10:10:58 AM »
You can do it, but just do not have any part of your body under the spring plate when you release it off the stop , especially a raised one. A Bentley manual should have the factory angle settings and you could base your preferred setting from those . An alignment would still be a good idea after it's all done.
