Author Topic: Another shifter rod question  (Read 7679 times)
Offline Dan
  • Crown Royal straight up....Thanks
« on: December 02, 2008, 04:37:34 AM »
Putting a buggy  together.The shortened shifter rod has a threaded end?Checked CIP'S web site this is for a super shifter?What coupling will work with this type of threaded female end?1971 pan and drive.Dan
We are Bigfun
Re: Another shifter rod question
« Reply #1 on: December 02, 2008, 08:43:51 AM »
The threaded end is for the trans side. Sounds like someone attached a coupler to it but you may be missing part of it.  The other end with the little cup is for the shifter end and will work with a stock or any after market shifter you want. Got a pic of what you have there?
Offline Dan
« Reply #2 on: December 03, 2008, 04:34:53 AM »
Coupler end is an add on!Camara dead last night too take picture. The threaded end looks like what is sold at CIP but can't find the rest.
We are Bigfun
Offline Dan
« Reply #3 on: December 03, 2008, 06:29:15 PM »
Here are the pictures.
We are Bigfun
« Reply #4 on: December 03, 2008, 07:20:36 PM »
dont bus shafts screw together someplace?
« Reply #5 on: December 06, 2008, 05:45:54 PM »
http://www.cip1.ca/ProductDetails.asp?ProductCode=ACC%2DC10%2D2660
It looks like this. You'll have to buy the whole thing but just use what you don't have.
Then you also need something like this.
http://www.cip1.ca/ProductDetails.asp?ProductCode=C13%2D16%2D5102
Offline Dan
« Reply #6 on: December 07, 2008, 05:40:47 AM »
Thanks for the info.I decided too start from sratch and cut down a shifter rod from a pan the same year as I'm building.Dan
We are Bigfun
