Author Topic: J Tube Or Not  (Read 1718 times)
J Tube Or Not
« on: March 21, 2004, 07:04:34 PM »
Went in engine tech but no one seemed to notice. Don't need heat in van wanted to run J tubes instead of heater boxes ,Pros and cons ? Motor run hoter or cooler ? block off pre heat hoses ? what about cooling deflection tin underneath usaully attached to heater boxes .? Any info would be appreciated . Running stock 1600dp
THX OUTKAST
J Tube Or Not
« Reply #1 on: March 21, 2004, 11:13:49 PM »
Hey O.K. , how's it going?  I don't think it would make or break anything. I do remember once hearing the opinion that the fan housing plugs should have a small hole drilled into them to keep a small amount of air flow like the heater box's do. Anyone else hear of this?
 and I'm sure you will also plug all the other holes in the rear tin?
J Tube Or Not
« Reply #2 on: March 22, 2004, 06:48:13 PM »
Thanks Hans ! Seems to be a hard question to get an answer on . Sounds like you had a good time at the dunes . You will have to post some more pics. Goy my rockers from airspeed last weekend should be installed next month ,engine bay sprayed dove blue , and motor close to going in .
talk to you later
