Author Topic: Arrows on the piston  (Read 2822 times)
Offline GL-Sheila
« on: November 04, 2008, 06:57:29 PM »
Quick question here, I understand that the arrow on the piston should be pointing towards the flywheel.  Just wanted to know exactly why, as the piston appears to be symmetrical, therefore, why can't it be oriented either way.  (The reasoning I'm asking is that we didn't check the direction of the arrows on the first two we installed and we're not sure if we had them oriented correctly. - wondering if we need to bother pulling the engine apart again to check/change the orientation.) Thanks
My other entrance is a porch.
Offline GL-Sheila
Re: Arrows on the piston
« Reply #1 on: November 04, 2008, 07:02:18 PM »
Ok, upon further research - we answered our own question - as the piston pins are off-centred, therefore the pistons can only be oriented in one direction.  Oooops - guess we'll be pulling it apart to check.  I guess better to do it now while the engine is still out of the vw.
Offline GL-Sheila
« Reply #2 on: November 04, 2008, 09:08:13 PM »
Well, it turns out that we did indeed put two of the pistons back to front on the one side, so just as well we found out.  (Better now than finding out the hard way!)  What can I say - Noobs!!!
Offline Jody
  • Junior Member
« Reply #3 on: January 01, 2009, 12:41:04 PM »
Glad you found out before you ruined a lot of part's !!!
 :)  Jody
