Technical
Wheel & Tire Forum
drop spindels or adjustable beam and why?
Topic: drop spindels or adjustable beam and why? (Read 4639 times)
egspot
October 26, 2008, 10:20:34 AM »
If you had a choice would you go for drop spindels or adjustable beam and why?
http://www.cardomain.com/ride/2142087
jefftrish
Re: drop spindels or adjustable beam and why?
October 26, 2008, 10:51:44 AM »
I would go drop spindels, I'm going on what I have read. Adjustable beams stiffen the ride, but the drop spindels keep the stock ride, some of the drop spindels increase the width up to a inch or two. I hope this helps. Later Jeff
Trevor P
October 27, 2008, 11:37:23 AM »
Both. Spindles to achieve most of the lowering and adjusters to fine tune it. While your in putting the adjusters that would be the time to chop the beam in order to get your wheels placed inside the fenders where you want them.
Jeremy
October 27, 2008, 02:49:01 PM »
I say both. If I recall you have both don't you? If you've got it taken apart to the point of doing the spindles it's not much more to replace the beam as well.
Jeremy
Crank
October 27, 2008, 06:12:01 PM »
Yup if you want to drop it... spindels, adjustable narrowed beam, castor shims and front tires.
...what Trevor said
O0
Randy
Formerly Tikitime
October 27, 2008, 08:16:24 PM »
All of the above.
That way you can have discs and adjust to desired height.
Randy
74 Vert Convert:
http://www.strictlygerman.ca/phpBB3/viewtopic.php?f=11&t=81
• 70 Blue Redo:
http://www.strictlygerman.ca/phpBB3/viewtopic.php?f=11&t=73
Technical
Wheel & Tire Forum
