Author Topic: REPOST: WTB: case and exhaust for 68 beetle  (Read 1868 times)
Offline Bianca
« on: October 01, 2008, 02:59:28 PM »
hello!
I'm looking for a new case - it cracked upon re-assembly (SO mad), if you have one or have any suggestions where to look any info is appreciated!
b-
« Last Edit: July 19, 2010, 09:41:55 AM by Bianca »
please be patient, I'm naturally blonde.
Offline vwguy
Re: WTB: case for 68 beetle
« Reply #1 on: October 01, 2008, 06:50:15 PM »
PM sent ,
Offline Bianca
Re: REPOST: WTB: case and exhaust for 68 beetle
« Reply #2 on: July 19, 2010, 09:41:40 AM »
I'm back!
after successfully burying this project for the last 2 years, I now need to fix it and get it running for real!
I still have a cracked case that needs to replaced, and I also need all new exhaust. where is the best place to buy exhaust parts? and where's a good place to get random bits now?
thanks guys!!
Offline notchback
« Reply #3 on: July 19, 2010, 05:23:19 PM »
CIP1.ca is really the only local place
Bruce McCrindle
AIRCOOLED WERKS
6047245576
New phone number above
« Reply #4 on: July 19, 2010, 05:45:10 PM »
and AVR, the question is where do you live?
Offline pittwagen
« Reply #5 on: July 19, 2010, 06:46:49 PM »
It would be helpful if you could identify the case you are trying to replace.  The serial # is under the generator support stand and above and slightly to the right of the crankshaft pulley.  If it is the original it should have an "H" prefix for 68.
As well you might want to share a budget number - $$ you have in mind for the repairs.  I'm sure there are lots of folks who will have what you need and might even be able to help with the repairs (taking your good parts out of your case and putting them into the new one) if that is required.  You might even be able to find a complete used long block that might also be cost effective and then all you would need to do would be to transfer the tin, manifolds, clutch etc. from yours to the new one.
Someone will likely have a good used exhaust system for you.  Do you need just the muffler assembly or do you need heater boxes as well?
Good luck.
Offline Bianca
« Reply #6 on: July 21, 2010, 09:09:31 AM »
um, yeah, I suppose location would help! I'm in Langley, BC.
I will check the serial #, thanks for letting me know where to look!
I need the heater boxes as well. I'm just looking for parts - I do all the work myself :)
Offline pittwagen
« Reply #7 on: July 21, 2010, 09:31:51 AM »
There are plenty of folks with good used parts available within easy reach of your location.  Post the case serial # when you get a chance and I'm sure the replies will follow.
Offline Ace-Vw-Herbie
« Reply #8 on: July 21, 2010, 09:45:23 AM »
Phone me ,I have lots of parts  .Thanks Ace  604-533-6722      ( south langley )
Offline Bianca
« Reply #9 on: July 21, 2010, 12:31:41 PM »
serial # is H0887873
