Author Topic: AHHHHH for F#$% sakes!  (Read 10817 times)
« on: August 24, 2008, 09:20:41 AM »
Just went over the notch for a trip to Oosoyoos yesterday and found that the front wheel cylinders are leaking!!!
I am a little torn as to what to do. I have bought the motor parts from Matt to build a 2275 this off season so the power next year is obviously going to be a little more.
My question is: If I go 4 wheel disc brakes, will I notice a considerable difference in braking power? Is it worth the time and energy or should I just talk to Geoff and let him bend me over the barrel (*snicker*) for a new set of cylinders and shoes.
Princess
Re: AHHHHH for F#$% sakes!
« Reply #1 on: August 24, 2008, 09:42:16 AM »
Not dvkk but its probably cheaper to buy disc brakes then your listed alternative. Dics brakes are a definite improvement.
« Reply #2 on: August 24, 2008, 09:53:11 AM »
It's not that easy, you have wide 5 and to run disc's it gets expensive! It's not like beetle brakes as those are common. The T3's use a different spindle...and early 61-63 are different again. I beleive CSP makes some brakes for it.....bend over!! ;D
Ps. I have the cylinders in stock, lol ;D
« Reply #3 on: August 24, 2008, 09:56:09 AM »
Ok but will the disc brakes be something I am going to have to do anyways? I just don't know if stock brakes are going to cut it for the 2275 or not.
Offline blarneyman
« Reply #4 on: August 24, 2008, 10:35:19 AM »
The HP doesn't dictate on the size or type of brakes you need. It's how heavy the car is and how hard you drive it  ;)
www.mbvv.org
My \"new\" 1970 Ghia
Offline Mowser
« Reply #5 on: August 24, 2008, 10:39:11 AM »
KEY POINT RIGHT THERE...
« Reply #6 on: August 24, 2008, 11:02:12 AM »
Dammit, they're on to me.......
« Reply #7 on: August 24, 2008, 12:24:19 PM »
just do it, get it over with.
Offline dirtydeedss
« Reply #8 on: August 24, 2008, 12:36:54 PM »
Type one beam and put that sucker on the ground ::)
« Reply #9 on: August 24, 2008, 08:55:17 PM »
agreed! slammedbus slammednotch looks good to me so far,
also try www.vdubengineering.com they do some wild stuff with brakes!
Offline dirtydeedss
« Reply #10 on: August 25, 2008, 12:33:41 AM »
hey jason..........i have all the parts...........rebuilt spindles and all :o
« Reply #11 on: August 26, 2008, 12:34:14 PM »
Ok.........................................you perverts stay away from my car!!!!
« Reply #12 on: August 26, 2008, 04:25:06 PM »
Roger that!
Thats the shits about the brakes man. the other option would be replace the front beam with that of a later model type 3 with factory disc brakes....please retain all the stock parts so I can buy them for the blue 63....
« Reply #13 on: August 26, 2008, 04:26:56 PM »
of course that would change your bolt pattern too....
« Reply #14 on: August 26, 2008, 07:09:08 PM »
And make the car look like bunk!
T3 drum brakes are good brakes when all parts are new and in good working order. Wide 5 discs would be best but not needed.....puting a T1 beam in that car would be my last....very last choice.
