Technical
Electronics & Car Audio Forum
turn signal symptoms
Topic: turn signal symptoms (Read 5809 times)
egspot
August 20, 2008, 10:46:06 AM »
My turns signals will flash 1-3 times and stop flashing. Could it be caused by "TURN SIGNAL FLASHER RELAY" ? Could one light not grounding properly cause this?
http://www.cardomain.com/ride/2142087
BUSDADDY
Re: turn signal symptoms
August 20, 2008, 02:01:18 PM »
Yes.
Well sort of, a ground issue usually makes one side act up and one side behave normally. Try cleaning the grounds anyways, including the one on the relay.
Last Edit: August 20, 2008, 02:04:50 PM by BUSDADDY
egspot
August 20, 2008, 11:50:15 PM »
Thanks man. I will look all the grounding and the relay.
egspot
October 03, 2008, 07:56:59 PM »
Thanks Stephan.
egspot
April 18, 2009, 02:49:07 PM »
I have ran out of options. I tried to fix it but have not been able to nail this one.
Anyone in the Burnaby area who knows they could fix it without screwing something else (under $100.00)
I do have a replacement switch/Relay.
Technical
