Author Topic: fuel coming out of exhaust and in oil  (Read 6350 times)
Offline bduchene
  • Junior Member
« on: August 02, 2008, 04:19:01 PM »
hi i am trying to get my type 2 motor running and i thought originally it was a weak spark problem. when i crank the motor over now i see that raw fuel comes out of the exhaust and seems to be draining in the oil. now i have taken out the mechanical fuel pump and replaced it with a pump that has only a max psi of like 10psi. i have no clue if the heads are screwed or what the deal is. does anybody have any suggestions or reasons? thanks
bd
Re: fuel coming out of exhaust and in oil
« Reply #1 on: August 03, 2008, 01:24:49 AM »
Maybe "RINGS?"
it is the only way i could explaine the oil.
Try a compression test.
« Reply #2 on: August 03, 2008, 09:18:20 AM »
Sounds like you've flooded it really bad, take out all the plugs and crank it a bit, let things air out while you find out about the weak spark then give it a try.
Offline Rob DVKK
« Reply #3 on: August 03, 2008, 11:10:37 AM »
drain the oil. Get a regulator for the fuel pump the pressure should be more than 4lbs for a carb application. Check you needle and seat or float level in the carb.
« Reply #4 on: August 27, 2008, 08:05:30 PM »
dont you mean "no more" than 4 lbs rob?
10lbs will most likely be blowing straight past the needle and seat, down the carbs into the exhaust, and past the rings into your oil...
depending on how much the electric pump flows your motor might be happy with as little as 2-3 psi...
I ran my fuel hungry 2276 on 3 lbs through a stock fuel line for a couple years before i upgraded the fuel system, more in Paranoia than anything else
« Reply #5 on: August 27, 2008, 08:48:54 PM »
Or the pump's diaphragm has a leak and fuel is siphoning into the crankcase.
Offline Rob DVKK
« Reply #6 on: August 27, 2008, 10:42:27 PM »
Yup, I guess I should read it again before hitting post.
