Author Topic: brake drums coming loose  (Read 12599 times)
Offline dirtydeedss
« on: July 15, 2008, 01:04:22 AM »
My 68' bugs rear drums keep coming loose... what might cause this, just a recent thing, i tourque em dow tight and the nut keeps backing off.
Re: brake drums coming loose
« Reply #1 on: July 15, 2008, 01:19:08 AM »
What method are you using?  How tight is tight?
Offline dirtydeedss
« Reply #2 on: July 15, 2008, 02:51:41 AM »
tries the impact as itght as it will go and then put a 1" drive breaker bar and jumping on it.
« Reply #3 on: July 15, 2008, 06:57:20 AM »
aint there a big ass cotter pin thats to help stop that?
Offline dirtydeedss
« Reply #4 on: July 15, 2008, 09:56:15 AM »
yeah but the nut backs off till it hits the cotter pin, i have sheared one cotter pin already
« Reply #5 on: July 15, 2008, 05:29:36 PM »
How do the splines in the drum look? any play?
« Reply #6 on: July 15, 2008, 06:51:19 PM »
wow unique, new drums? used drums perhaps they dont spin true, or else you like doing high speeds in reverse
Offline dirtydeedss
« Reply #7 on: July 15, 2008, 07:26:13 PM »
they are not new, been running them since last year, ill check to see if there is play next time they come loose, shouldnt be too long ::)
« Reply #8 on: July 15, 2008, 09:34:51 PM »
... then put a 1" drive breaker bar and jumping on it.
We need to know how far from the axle you are pushing on the bar (feet) and how much static weight (lbs) you are applying.
Offline dirtydeedss
« Reply #9 on: July 15, 2008, 09:38:24 PM »
lol i tightened them tighter than i do on my other cars and have no problem on the other vw's.
« Reply #10 on: July 15, 2008, 09:54:57 PM »
that's right.
for instance....2ft long breaker bar x 150lbs standing on the end of it = 300ft/lbs torque
hey deeds.....are you experiencing trouble with both left rear and right rear drums?
i cant help but think it's got something to do with the excessive negative camber you have in the back. how are the bearings? splines on the drum? splines on the axle shaft? threads on the axle shaft? threads on the castle nut?
Offline dirtydeedss
« Reply #11 on: July 15, 2008, 10:01:41 PM »
all the threads are good, drivers side backed off once and the pass side i re tighten it every few days.  the bar is 2 feet long and im 165 lbs. it was tight.  I also read something about this on samba, i think i may need some new drums.
Offline piercedvw
  • aka Karmann Ghia
« Reply #12 on: July 16, 2008, 08:50:11 AM »
Bigger cotterpins.  :-\
« Reply #13 on: July 16, 2008, 10:49:07 AM »
new or used axle nuts? are you sure that the drums are actually seating properly? Maybe you need a spacer?
Offline dirtydeedss
« Reply #14 on: July 16, 2008, 05:14:13 PM »
yeah they are seating properly, they have been good for almost a year up untill about a week ago
« Reply #15 on: July 16, 2008, 10:35:07 PM »
That is minimal.  I use a 5' pipe.  With good threads, you should be able to give it 400+ ftlbs.
