Author Topic: 944 Brakes Install For Beetle  (Read 5301 times)
Offline driverfound
« on: March 12, 2004, 09:06:23 AM »
I was wondering if anyone has the exact measurements for the front hub machining.  I still have to purchase the caliper type spindals. should I buy NOS or mexican?  Should I use the VW wheel bearings?
I'm having troubles fitting the trailing arm to the torsion arm too.  Is there an after market torsion arm that will fit the 86 and newer trailing arm bolt pattern.
« Last Edit: March 12, 2004, 09:07:41 AM by driverfound »
Offline s3racing
« Reply #1 on: May 02, 2004, 08:35:20 AM »
B)  B) Hay let me know how your conversion goes I'm looking at doing a similar swap. On my 75 Beetle. What else are you doing to your car?
Offline s3racing
« Reply #2 on: May 02, 2004, 08:39:38 AM »
Oh just an idea Porsche excelence has a few articles on 944 brake conversions they may have the specs or be able to send you in right direction.check out nov 2002 issue it has an article there in I'll do some readin see if it may have something that may be of help.
Offline s3racing
« Reply #3 on: May 02, 2004, 09:00:48 AM »
B) ok sorry but that issue will be of little help as it goes threw an upgrade on a 944 maybe contact the mag and see if they can give you any info that will help. They are very knowlegeable bunch.
Excellence,P.O. Box 1529, Ross, CA 94957
addres this same question to Letters to the Editor. Its an awsome Mag eh!
