Author Topic: Advice? 3 Cylinders  (Read 1314 times)
Offline splitworld
Advice? 3 Cylinders
« on: June 10, 2008, 10:23:54 PM »
So I had my type 3 running great after i got her tuned up but it started running shitty again yesterday.  I checked it out and #3 cylinder was not firing anymore,  I switched the plugs with another cylinder and suddenly I was back in business.  But not for long.  I am back running on 3 cylinders again.  I cant figure out why the #3 cylinder keeps burning out.  Timing is good, wires are new, plugs are new, carbs are new, heads are new. WTF ??? ??? ??? ??? Is it burning to hot? should I put a higher temp plug in?  Any help would be greatly appreciated.
71 SQUARE
Offline Cameron
Re: Advice? 3 Cylinders
« Reply #1 on: June 11, 2008, 08:08:32 AM »
Define "burning out".
Checked valve lash lately?
What kind of carbs? I'm thinking there may be a clogged idle circuit.
Offline splitworld
« Reply #2 on: June 11, 2008, 01:53:58 PM »
Valves are adjusted.  I changed the plug again today to a cooler burning plug, runs even worse.  I've got duel 34 empi.  Cant say for sure the plug is burning out but when I pull the wire off to that cylinder there is no change in the engine performance.  I had 2 different carbs on the car, still the same problem.  with the new carburetors it makes it very hard to do a compression test.  Im really flat for Idea's the car has a mind of its own.  The thing that bothers me is that it ran perfect for like 3 days. 3 cylinders is cursed.
71 SQUARE
« Reply #3 on: June 11, 2008, 02:24:41 PM »
I am no expert but, check your cables from dist to plug and your rotor, dist cap etc.
Offline splitworld
« Reply #4 on: June 12, 2008, 10:20:01 AM »
yeah checked the wires, and cap, and changed them both.  Im thinking now that a valve might have gotten stuck in, when I got the heads rebuilt maybe they didn't seat the heat properly, but ive got to pull the motor again.....no fun for summer :-[
71 SQUARE
