Author Topic: side plates-- for bus  (Read 3735 times)
« on: June 04, 2008, 06:28:45 AM »
Hey all,
   i need some help here, im going to build a narrowed bus beam, i can get side plates that will for sure fit split busses, i will be building a bay beam, now other than the mounting holes, does anyone else know if the tubes are in different locations or anything like that??? any help is good help here
Thanks!
Offline dale-j
  • Steve
Re: side plates-- for bus
« Reply #1 on: August 13, 2008, 11:24:14 AM »
Franklins makes them.  http://www.franklinsvwwerks.com/
Offline notchback
« Reply #2 on: September 16, 2008, 06:23:14 PM »
Make some yourself they are super easy. Just use some 3/8 plate and make a template off a stock set up. Ive done this I can walk you through it
Bruce McCrindle
AIRCOOLED WERKS
6047245576
New phone number above
Offline buggybilly
« Reply #3 on: October 28, 2008, 07:27:21 PM »
the space between bay and link pin is
bay window bus tube to tube 18 cm bay is 4 cm wider drum to drum
split window bus tube to tube 14 cm cant tell you the width because mine is 14 cm narrower than the bay
