Author Topic: 12 volt conversion  (Read 1734 times)
Offline Schvengy
12 volt conversion
« on: May 20, 2008, 05:59:42 PM »
I am getting alot of different people telling me different things ...????????
What needs to be done to the car to change to 12 volt?
65 beetle 1300cc
Willis
Re: 12 volt conversion
« Reply #1 on: May 20, 2008, 08:04:42 PM »
change all lights incl dash, alt or gen to a 12v, voltage reg. for the starter I know that guys have left 6v ones in and have them work for years, it will spin much faster and as long as your motor is healthy and you don't have to crank it for 30 sec + every time to start, i'd leave it until next time you have the motor out and then switch the flywheel and starter bushing and oh yeah clearance the bellhousing
Offline Schvengy
« Reply #2 on: May 21, 2008, 07:35:23 PM »
« Reply #3 on: May 21, 2008, 07:38:35 PM »
no probs, forgot wiper motor ;D
« Reply #4 on: May 21, 2008, 07:40:35 PM »
Wipers, signal flasher, fuel gauge, radio and the choke coil on the carb too.
« Reply #5 on: May 21, 2008, 07:47:38 PM »
I've run a 6v flasher relay on 12 for years
Offline KOOL-AID MAN
« Reply #6 on: May 22, 2008, 07:42:40 PM »
doesnt the 6 volt wiper motor still work?
« Reply #7 on: May 23, 2008, 08:43:07 AM »
sure if you want it to go so fast it chucks the blades off :D
there are resistors sold to step down but I hear they're junk and burn out. most find a 67ish motor or change the armature
