Author Topic: front end lowered - one side lower ..rubbing ?  (Read 5870 times)
Offline Schvengy
« on: April 28, 2008, 08:17:16 PM »
Installed new 2" narrowed beam , new shortened torsion springs , castor shims,  new shortened tie rods , new gas shocks ...is set at lowest setting .....passenger side i can get my fingers between the tire and fender..no rubbing
drivers side can't get fingers in between fender and tire ....and when turning i get rubbing.
i have removed the shocks and checked ...same issue
where do i go from here ?
Willis
Offline Chris W
  • Portland Oregon
Re: front end lowered - one side lower ..rubbing ?
« Reply #1 on: April 28, 2008, 09:54:50 PM »
I bet you have a non original fender on one side.
« Reply #2 on: April 28, 2008, 11:08:25 PM »
good call chris....
was the difference in height noticeable before the drop job?
a few other things to check....with the car on level ground measure the rear height with a tape measure (sagging rear or mis-adjusted rear torsion bars), check the front tire sizes and check your tire pressures (sounds dumb but you cover every angle, eh)! ;)
« Reply #3 on: April 29, 2008, 01:40:32 PM »
Park on a flat level surface.  Measure from the outer ends of the beam to the ground.  This will tell you if the car is tilted.  If it is not tilted, what Chris said is probably your problem.
If it's tilted, correct it by altering the height at one side on the rear.
Offline Schvengy
« Reply #4 on: April 30, 2008, 04:04:51 PM »
I measured the front beam on the outer edges and the drivers side is lower by 1/4 inch .
What is the procedure to correct the tilt???
Willis
« Reply #5 on: May 03, 2008, 08:10:41 PM »
Raise the left rear until the front beam is parallel to the ground.  Find some weights to sit on your left seat to simulate your weight, then correct the tilt.
Measure from the rear torsion housing to the ground too.  This will confirm the tilt.
Offline Schvengy
« Reply #6 on: May 03, 2008, 09:12:06 PM »
thanks   ;D
Offline rattlenbang
  • Junior Member
« Reply #7 on: May 14, 2008, 10:37:43 PM »
damn, that's EXACTLY what my 68 single cab is doing after i lowered it - but on the passenger side. this post doesn't mention model but would this fix apply to this old truck?
« Reply #8 on: May 15, 2008, 12:00:29 AM »
yes
