Author Topic: 7" And 8" Fuchs On An Early Beetle?  (Read 1594 times)
Offline surgerypending
« on: April 09, 2008, 06:17:16 PM »
I have a set of 15x7\" and 15x8\" wheels that I'm thinking about putting on the 58. I'm just wondering if these will fit and with what tire size?. I have a 3\" narrowed beam and I was thinking about short axles in the rear. I suspect i'll have to run spacers with this set up?
Has anyone done this before ?
Any thoughts?
Gerry
Offline kafer_kid86
    • http://streetfire.net
« Reply #1 on: April 09, 2008, 09:41:18 PM »
im using the same set up on my 66' but 16x7s, for the front im gunna go 195/40/16 and the rear 205/55/16
but PM chris beere (notorious bug) he used my set up on his 65 with an IRS so he will know better then me
Jeff Pedersen
                \"the other jeff pedersen\"
« Reply #2 on: April 10, 2008, 01:07:18 PM »
7&8x15\" Fuchs are under my car right now.
I have used 195/50s, 205/50s and 205/55s on the front, and 225/50s and 215/60s on the rear.  This is an IRS/BJ car.
Using short axles, you will be able to fit the 8s, although I don't think you will be able to use a really fat tire.  Any extra track due to wider brakes will work against you.
The front may require a spacer.  My BJ beam is 3.75\" shorter and I needed a spacer.
« Reply #3 on: April 10, 2008, 05:45:53 PM »
Thanks Bruce
« Reply #4 on: April 10, 2008, 09:12:33 PM »
Gerry, if we can arrange for a few cars to be at the same place, we can test fit tires and wheels.  I know Gary, Alan, Mirko, and Darren K all run P pattern with VW short axle swing.  I've got both 215/60s and 225/50s mounted on 8\" Fuchs that could be tested on their cars for fit.
Alan has run 225/50/16s on 7\" Fuchs, and is currently using 205/70/15s on 7s.  The 8s have the extra inch all on the outside.  Maybe Alan can tell you what clearance he has.
« Reply #5 on: April 10, 2008, 11:06:39 PM »
...I know Gary, Alan, Mirko, and Darren K all run P pattern with VW short axle swing...
plus geoffs 59 (allthough i'm not sure if he's running short axles or not).
that party would be off the \"fuch\"!! :lol:
« Last Edit: April 10, 2008, 11:07:18 PM by silas »
« Reply #6 on: April 10, 2008, 11:23:29 PM »
Geoff's car has that gay IRS suspension, that's why I didn't include him in the party.
« Reply #7 on: April 11, 2008, 08:14:17 AM »
\"fuch\"en eh!!! :rockon:
« Last Edit: April 11, 2008, 08:15:17 AM by brodie »
« Reply #8 on: April 11, 2008, 08:56:22 AM »
Where can one buy one of those?
« Reply #9 on: April 11, 2008, 04:37:37 PM »
Hey Bruce,
I'm definately not that close yet as to start fitting tires.
I just got these wheels last week and i'm planning a slightly different look with the 58 than my oval..more of a driver. I seen you flying out the freeway over the Port Mann last spring in your yellow car and the look of your car stuck in my mind. Looks like a fun car to drive!
Gerry
