Author Topic: Venting My Block  (Read 5519 times)
Offline driverfound269
Venting My Block
« on: March 31, 2008, 09:05:57 AM »
Can I vent crankcase gases through the fuel pump hole since I'm running a electric fuel pump?
Or could it be used as a oil return from cooler?
Thoughts anyone?
Mike
Everytime I build it idiot proof, they build a better idiot!
Venting My Block
« Reply #1 on: March 31, 2008, 04:42:13 PM »
as a breather yes definatly, as a oil return point? not a chance. the oil returning from your cooler hasnt been to the bearings yet....
Venting My Block
« Reply #2 on: March 31, 2008, 08:56:46 PM »
not sure what you're building but I seem to recall someone with a rev monster motor having problems venting from the fuel pump plate. something about a lot of oil getting flung up through the line and filling the breather box, overflowing before it could drain back. I want to say it was jim martin, could be wrong though
Offline dirtydeedss
Venting My Block
« Reply #3 on: March 31, 2008, 09:40:30 PM »
does the bottom end not vent through the oil filler or am i missing something?
Venting My Block
« Reply #4 on: April 01, 2008, 08:10:12 AM »
That's ok........won't the oil get splashed all over the bearings on the way down Dannyboy??????
I'm kidding dood.......well sorta   :huh:
Venting My Block
« Reply #5 on: April 01, 2008, 08:08:48 PM »
Maybe I should have been clearer remote oil cooler return into block off plate,still going to run stock cooler also
Venting My Block
« Reply #6 on: April 01, 2008, 08:14:32 PM »
Return the remote cooler to the fuel pump block off, no dont do that.  Either full flow the case or buy a full flow oil pump like this http://www.cip1.ca/ProductDetails.asp?Prod...C%2DC10%2D5386E
