Author Topic: Swap Want List  (Read 6169 times)
Swap Want List
« Reply #30 on: April 11, 2008, 02:27:55 PM »
Anyone going have:
OG rear eng tin - without heater holes.
1 frame horn bolt
36hp or 1600 gavin?
don't even know if it's differnt but i can check for you
Swap Want List
« Reply #31 on: April 11, 2008, 03:09:27 PM »
Anyone going have:
1 frame horn bolt
got your bolt and a tin that I filled the holes in on. I can bring it and see if you can use it.
Offline nivag
  • Gavin Lee
Swap Want List
« Reply #32 on: April 11, 2008, 04:29:59 PM »
Thx Josh See you Sat.
Offline Rob DVKK
Swap Want List
« Reply #33 on: April 11, 2008, 05:13:05 PM »
What are you camping out?
« Last Edit: April 11, 2008, 05:13:30 PM by Rob DVKK »
Offline vanBoven
Swap Want List
« Reply #34 on: April 11, 2008, 05:49:31 PM »
12 volt armature to convert my wiper motor, cip and wolfburg west r out.
Swap Want List
« Reply #35 on: April 11, 2008, 07:23:18 PM »
aren't you............early bird gets the hot deals :D
Swap Want List
« Reply #36 on: April 11, 2008, 09:14:09 PM »
Got my stuff ready
48 idfs with manifolds linkage and air cleaners
Empi Aluminum full flowed, clearanced case cut for 94s
Bugpack 40 x 35.5 heads cut for 94s
New Forged 78mm crank
Uni Tech rods
34 pict carb with manifold
Weber single carb manifold
Plus a bunch of other goodies
Mark Moryse-Edge will be selling my stuff as well as his own stuff at the swap. Go by and say hi. He's ok.........just looks a little odd.   :P
Judson Supercharger
T2 Scat shifter
Split bus bumpers
Swap Want List
« Reply #37 on: April 12, 2008, 08:28:55 PM »
black pop out covers
Offline ScreamnStroker
Swap Want List
« Reply #38 on: April 12, 2008, 09:00:10 PM »
- scat dragfast shifter
- steering box
- L\P tie rods
- off road steering wheel (a cheapo is good)
- cheap running 1600 ( no exhuast needed )
-930 stub axles
Swap Want List
« Reply #39 on: April 12, 2008, 09:04:21 PM »
My notch is loaded and ready for the morning! see ya there
Offline nivag
  • Gavin Lee
Swap Want List
« Reply #40 on: April 12, 2008, 09:24:44 PM »
Anyone going have:
1 frame horn bolt
36hp or 1600 gavin?
Hey Russ, not sure what the fit difference between the 36hp and 1600? Do you have either? The small and large pully tins are the main ones I need.
Thx, G
