Author Topic: Beetle Door Hinge Repair  (Read 4263 times)
Offline kombikruiser
« on: January 22, 2008, 11:40:36 PM »
My cuz is  repairing a door hinge on my 67 beetle,  and has drilled out the rivets on the door part of the hinge and removed it from the door; so he has both parts of the hinge on the bench so he can install an oversize hinge pin.May have been a bad move...
His question is;
what would be the best way to re-attach the hinge to the door. Obvuisly the original size rivet would be ideal, but is probably not a viable option,
 ie; would never be able to find them...
The door is primed and all body work done , so any welding would probably warp...
Have any of you come up with a solution in this situation...
Nut and bolt? lame...
Thanks gang
vic
'57 Type 1
'67 Type 1
'66 Type 2
'67 Type 3 Fastback
« Reply #1 on: January 23, 2008, 10:45:34 AM »
I think VW actually listed a bolt/nut kit to repair this back in the day. I will have to check my shop manuals.
« Reply #2 on: January 23, 2008, 03:48:33 PM »
Workshop manual A-15 page 2. Part#'s as follows:
N 100 847 01 (counter sunk head bolt)
N 012 108 2 (washer)
N 011 008 8 (nut)
These parts are still availbale at your local dealer and they are cheap.
