Member's VW's
Started Work On My '65
Topic: Started Work On My '65 (Read 11286 times)
goldfish
January 04, 2008, 09:39:52 PM »
I got me beetle about a year ago from a member on here. Until a month ago it has been up in my barn waiting for room in the garage. I finaly made room and moved the other half finished MGB project up to the barn. I just started doing work 2 weeks ago and just do whatever I can every now and then when I have time. I have the body pretty much ready to come off. Anyway here are some pics. some of them are pretty blurry
Outside
In the carport
Fenders off
Ugly floor pan Seats out
Wiring mess
Engine is out
Under the hood
before
now
Fenders, hood, new floors
Dash
All cut up
Headliner
Seats
More pics here:
http://s126.photobucket.com/albums/p94/Con...Beetle/?start=0
I'll add more pics as I go.
'65 Type 1
beetleboy
January 10, 2008, 09:45:30 PM »
looks good man
KOOL-AID MAN
February 06, 2008, 05:24:37 PM »
Sweet! good to see the old car again... sorry about my shitty fiberglass repair job on the inner heater channel, It was just a temporary fix up.... Good luck with the project!
Tom
February 06, 2008, 06:56:02 PM »
nanoose bay!!! i'll have to stop in for a quick bevi when i'm on the island next.
if you're close to the old island highway, i've probably driven by your house many times over the years!!
Last Edit: February 06, 2008, 06:57:28 PM by silas
goldfish
February 06, 2008, 07:53:23 PM »
Im in Rockinghorse. Near the pub down at the end of a road.
We cut all the fiberglass off and the body is now off the car but we dont have anywere to put it so its no 2 pipes with 4 sawhorses. when we have time were going to cut the old pans out with the plasma cutter.
'65 Type 1
goldfish
February 25, 2008, 08:07:27 PM »
Body is outside and covered, Me and my dad cut out the driver side floor and have the new floor ready to be put in. didn't have time to cut the other out.
'65 Type 1
kafer_kid86
February 25, 2008, 09:52:39 PM »
ohhhh ya she was a beaut eh tom! gotta love those floors i remember them to well
Jeff Pedersen
\"the other jeff pedersen\"
goldfish
Re: Started Work On My '65
Reply #7 on:
October 26, 2008, 09:31:02 PM »
We finally got around to do some work on it. After taking all the junk that we put on top of it off the grinded off all the remains form the floor pans and got the new ones welded it. I might start cleaning up some of the other stuff tommorow. then I can start working on the body.
'65 Type 1
goldfish
Reply #8 on:
November 20, 2008, 05:58:51 PM »
Got some more work done yesterday and today after school..
Got the Transmission out
Transmission waiting in line
Got the front beam off
Front part before:
And after
'65 Type 1
goldfish
Reply #9 on:
January 24, 2009, 08:11:05 PM »
Moved it out of the shop yesterday to do some sandblasting. Its almost done, just needs a some more touching up at the back. Then it needs to get a bit warmer so we can primer and paint it
Thats to bottom, I'll flip it tommorow when I'm done sand blasting
'65 Type 1
KOOL-AID MAN
Reply #10 on:
January 25, 2009, 01:38:20 AM »
looks like your doing some good work there! one thing i might suggest is running the fuel line through the transmission tunnel. It's a bitch but you got it all apart so it might not be to too bad.
Bruce
Reply #11 on:
January 25, 2009, 11:26:17 AM »
I second that recommendation. It took me 10 min to insert a new fuel line in a 66 pan
with the body on
. At this point, it will be easy to put it inside.
goldfish
Reply #12 on:
May 06, 2009, 07:48:28 PM »
Thanks for the advice, I'll probably do that.
I started doing some work on the tranny.
I took the axles off
and painted the transmission.
'65 Type 1
Jeremy
Reply #13 on:
May 06, 2009, 08:28:30 PM »
Nice work there GoldFish. I noticed you pressed the bearing housings off. Are you going to narrow the axle tubes?
Bruce
Reply #14 on:
May 10, 2009, 11:04:55 AM »
You need to grind off the paint from the mounting flange for the starter. Starters don't work very well when they are electrically insulated from the rest of the car.
goldfish
Reply #15 on:
October 25, 2011, 10:26:51 PM »
Forgot I had a thread on here. It's a Baja now, converted to irs, bus transmission, 6" over beam and disk brakes all around. Here's a couple recent pics.
'65 Type 1
Member's VW's
