Author Topic: 55 Beetle Bowden Tube  (Read 4548 times)
Offline volks14wagen
« on: December 02, 2007, 06:32:50 PM »
I have a very original 55 beetle which i am currently getting ready to drive very Rat look, and in tryin to adjust the clutch cable broke the end off so i went to replace it and the new cable will not fit threw the original bowden tube.So i bought a new one from CIP and am having a hell of a time gettin the old bowden tube out. I dont know if there is an easy solution or if i maybe just have to grind it out any help would be greatly appreciated...Thanks
« Reply #1 on: December 02, 2007, 07:06:27 PM »
If your car has the OG trans, then you can unbolt the bowden tube bracket from the trans in order to aid in removal/installation of the tube.
« Last Edit: December 02, 2007, 07:06:41 PM by Trevor P »
« Reply #2 on: December 03, 2007, 11:01:56 AM »
Should it not just slide out from the pan or is it hooked to something up there to cause i reefed on it pretty hard with no sign of lettin go
« Reply #3 on: December 03, 2007, 11:56:37 AM »
it should slide out from the pan yes.mabey it has rusted to it a little??
