Author Topic: Ring & Pinion  (Read 7541 times)
Offline Brassmonkey
Ring & Pinion
« on: November 24, 2007, 01:56:26 PM »
Hey I need help to identify some ring & pinions I have what do I have to do all I know is that ones from early swing (6volt syncro) and the other is from a single side cover irs both type 1, I'd like to find out what I have to do after I count the the teeth on the ring & pinion
Thanks Glenn
Ring & Pinion
« Reply #1 on: November 24, 2007, 04:13:44 PM »
Post the tooth count numbers.  Divide the ring gear by 8 to get the ratio.  Your early one is 35/8 = 4.37:1
Look carefully on the side of the ring gear for a 4 digit stamp.  There will be a letter with 3 numbers like G831 on the late ring gear.  Post those.
Offline Brassmonkey
Ring & Pinion
« Reply #2 on: November 24, 2007, 07:43:19 PM »
Ok I'll post the findings tomorrow I'll be ripping trannies apart tomorrow I also have a 5 rib but that should have a 4.86 I think.
Offline Brassmonkey
Ring & Pinion
« Reply #3 on: November 25, 2007, 09:10:00 PM »
The divide by 8 does that work with type 2 ring & pinions to? never mind I looked at my 4.57 and I just divided by 7 thanks.
« Last Edit: November 25, 2007, 09:47:43 PM by Brassmonkey »
Offline Brassmonkey
Ring & Pinion
« Reply #4 on: November 25, 2007, 09:46:17 PM »
Ok so I have a 4.37 and a 3.88 for type 1 and a 4.57 and a 4.86 for type 2 wow I hait taking trannies apart know.
Ring & Pinion
« Reply #5 on: November 25, 2007, 10:37:37 PM »
What are the letters next to the tooth count stampings on the ring gears?
Offline Brassmonkey
Ring & Pinion
« Reply #6 on: November 25, 2007, 10:39:17 PM »
I still have to take the rings off the diff or do I
Ring & Pinion
« Reply #7 on: November 25, 2007, 11:31:38 PM »
No, the marks are on the OD of the ring gear.  Wipe away the gunk.
Offline Brassmonkey
Ring & Pinion
« Reply #8 on: November 29, 2007, 09:17:06 PM »
OK the late r&p #s are G831 & the 5 rib is K734 the other type 1 r&p I'll post tomorrow and the other bus r&p is in my buggy
