Author Topic: Door Hinge?  (Read 1301 times)
Offline stan62vw
Door Hinge?
« on: September 17, 2007, 07:53:37 PM »
Hello ,is the upper hinge pin threaded in.I would like to remove it with out damageing the hinge.Iam afraid to heat it up do to panel warp. I used liqiud wrench and wacked with a hammer no movement.Any advice would be great thank you  :rockon:
Door Hinge?
« Reply #1 on: September 17, 2007, 08:15:50 PM »
It's a press fit.
The only method that seems to work well is heating it, then support the hinge and use an airhammer to drive it out.
« Last Edit: September 17, 2007, 08:16:03 PM by Trevor P »
Offline doubledoor
Door Hinge?
« Reply #2 on: September 19, 2007, 08:45:59 PM »
the best way i have found with out heat or beating the piss out of it till the hinge falls off is to take the door and put the hinge in a vise. Use a bigger socket on the top of the hinge that goes over the pin and a short punch on the bottom and press it out. it is tricky with one person but it can be done.
good luck hope this helps :D
49 ford coupe
Offline stan62vw
Door Hinge?
« Reply #3 on: September 20, 2007, 01:25:34 PM »
Thank-you for the advice, I will give it a try. :rockon:
