Author Topic: Rod Bearings  (Read 4543 times)
Rod Bearings
« on: September 12, 2007, 07:09:31 PM »
Hey guys, Im trying to find chevy rod bearings for my 84mm crankshaft. Cip does not carry them. Any suggestions? Thanks Brian.
Rod Bearings
« Reply #1 on: September 12, 2007, 07:42:27 PM »
Not DVKK (lately that doesn't really seem to matter) but I used  clevite 77 part# 610P's. You need to clearance the edges for the radius on the journal cheeks but that was only a 4-5 beer job :D using an exacto knife, then jiffy marker the area, torque them onto the crank and rotate to see if you took enough off, repeat if needed.....hence needing the 6 pack ;)
In my extensive poking and prodding for info on this build I was told that clevite 745hn's are the shit (better material and teflon coated I think...look them up) and you don't need to modify them like the 610p's.
Or I think it was alan u that reccomended the calico ones.
« Last Edit: September 12, 2007, 07:44:02 PM by josh »
Rod Bearings
« Reply #2 on: September 12, 2007, 09:11:50 PM »
Thanks dude, Ill check into that.  :blush:
Rod Bearings
« Reply #3 on: September 12, 2007, 11:47:00 PM »
....You need to clearance the edges for the radius on the journal cheeks but that was only a 4-5 beer job :D using an exacto knife, then jiffy marker the area, torque them onto the crank and rotate to see if you took enough off, repeat if needed.....hence needing the 6 pack ;)....
there is some good info on this procedure about half way down the page in the link below...
http://www.airspeedparts.com/community-for...14&t=914&st=180
Rod Bearings
« Reply #4 on: September 13, 2007, 07:02:29 AM »
Found em.  :D
