Author Topic: Case Clearancing For 84 Mm Crank  (Read 8307 times)
Offline neil68
« on: September 04, 2007, 07:31:07 PM »
Alan, or any others running 2332 cc type 1's:
In your current engine, are you using a crankshaft with VW journals or chevy size?
I'm looking at increasing my displacement to 2332, but would prefer to re-use my current 5.5\" H-beam rods (to stay within a reasonable budget).  However, these rods have VW-sized journals, which would probably require some extra clearancing inside the case...I'm currently using a recent Brazilian mag case (three years old).
Thanks!
Neil :)
Neil
Der Kleiner Rennwagens
'68 Beetle 2332 cc
12.6 sec at 109 mph
« Reply #1 on: September 04, 2007, 09:18:32 PM »
Neil, Alan is using a Chev journal crank.
VW journals can be made to work, but it gets very very close.  What rod bolts do your rods have, 5/16\" or 3/8\"?  Who's rods are they?
Offline neil68
« Reply #2 on: September 04, 2007, 09:43:22 PM »
Hi Bruce,
I currently have CB Performance H-beams with 5/16\" ARP 2000 bolts (didn't feel the need for 3/8\" bolts with my current 2017 motor and only 131 HP at the wheels).
I may go with either 2175 or 2276 displacement for winter motor upgrade, if the 84 crank is not in the cards...
Thanks,
Neil.
Neil
'68 Beetle 2332 cc
12.6 sec at 109 mph
« Reply #3 on: September 05, 2007, 10:23:55 AM »
my 2276 has vw journals, and it got quite thin in the roof of the case, i would imagine that an 84 would be really close. imho i think the best thing to do is save up a bit more and buy an 84 with chev journals and get some scat h-beams to match...
« Reply #4 on: September 05, 2007, 12:13:27 PM »
The rods you have may work with an 84 stroke VW journal crank.  If you had 3/8\" bolts, they would not fit.  I know that 5/16\" rod bolts in Eagle rods on an 84 stroke VW journal crank can be made to fit.  Whether the CB rods are the same as Eagle is unknown to me.
« Reply #5 on: September 06, 2007, 12:31:13 AM »
btw, my 2275 has the 3/8 bolts
« Reply #6 on: September 06, 2007, 04:55:11 PM »
2332cc scat H beam 3/8\" bolts, 84mm DMS welded crank with chev (actually buick) rod journals. My case was done by rimco, I honestly didn't look at how close (thin) the clearancing was.
If your case is on it's last legs you could always go to a cb \"raised roof\" alum case to gain some room.
Offline neil68
« Reply #7 on: September 09, 2007, 01:56:19 PM »
Josh,
That's my dilemma.  My mag case is only three years old, with fairly low mileage, tight lifter bores, standard mains, bluerprinted matching oil pump, the whole package is there and I could use slip-in 94's (90.5 case bore).
However, I can also get a raised-roof aluminum case for $600 CDN that's already cut for 94's and then pretty much drop in an 84 crank.
Thanks for the suggestions...
Neil.
Neil
'68 Beetle 2332 cc
12.6 sec at 109 mph
Offline neil68
« Reply #8 on: September 29, 2007, 09:35:10 PM »
Thanks for the input.  I placed my order today with Concept 1 for an 84 mm crankshaft with chevy journals and 5.5\" rods, so I'll go with a 2332 cc for next season.
It looks like the amount of clearancing that I've already done on the case for the current 78.4 x VW journal rods, will only require a bit more work to make the 84 x Chevy journal rods fit.
Also toying with replacing the current FK8 with an FK 10...
Neil
'68 Beetle 2332 cc
12.6 sec at 109 mph
« Reply #9 on: September 29, 2007, 10:59:25 PM »
but the k-8 is such a wicked cam!
« Reply #10 on: September 30, 2007, 08:11:00 AM »
sell your rods, regrind to a chevy rod journal ,get it wedgematted at the same time,buy new rods.done
Offline Darren
« Reply #11 on: October 01, 2007, 10:47:35 AM »
I tried a K10 over a K8 a few years ago on a 2275 with no other changes and if I were you I would stick with the K8
Chow,
« Last Edit: October 01, 2007, 10:49:24 AM by Darren »
« Reply #12 on: October 01, 2007, 11:52:14 AM »
Chow,
Speaking of case machining ........................................................
« Reply #13 on: October 01, 2007, 02:40:02 PM »
Chow,
but he's going up in displacement from a 2017 to 2332 so would that benifit from more cam? not that i'm questioning a real engine builder.........just wondering B)
Offline neil68
« Reply #14 on: October 03, 2007, 07:02:35 PM »
We have one or two more Friday-night street legal races here in Calgary and then I'm going to send my heads and manifolds to K-roc for some work.  The heads are \"out-of-the-box\" CB 044 CNC oval-ports and the manifolds probably need some porting as well.
I will stay with the FK8 for now and then perhaps experiment with other cams later, if necessary.  The FK8 is so nice for street driving, so that is certainly a plus :)
« Last Edit: October 03, 2007, 07:03:05 PM by neil68 »
Neil
'68 Beetle 2332 cc
12.6 sec at 109 mph
