Author Topic: Engine Leaking !  (Read 4394 times)
Offline vwsteve
  • Junior Member
Engine Leaking !
« on: August 22, 2007, 11:14:04 PM »
anyone want to earn a couple bucks and beer
i am losing oil like a bastard from behind the fan and need help to solve this problem
the car is a 64 type 1 with a 1500 single port
thanks
Steve
Offline Cameron
Engine Leaking !
« Reply #1 on: August 23, 2007, 08:36:54 AM »
Sounds like the oil cooler has come loose. A problem that's not uncommon. It's not too hard to fix.
Offline piercedvw
  • aka Karmann Ghia
Engine Leaking !
« Reply #2 on: August 23, 2007, 08:49:34 AM »
Mmmmmmmmmm.......beeeeeeeeeerrrrrrrr.
Engine Leaking !
« Reply #3 on: August 23, 2007, 10:06:42 AM »
Get under the car and look under the engine (front of it) , Is the leak on the engine between the engine and trany? That could be the  flywheel seal. It would require that you drop the motor and have the tools to take the flywheel off to replace it.
If it is comming from under the fan housing to the front and back of it, the leak will be from the cooling tower. Likely you can look in the back of the motor and see oil leaking under the fan housing or put squeze your  hand behind the housing and feel for the leak. This is an easier fix, You will have to remove the gen.alt and probably the carb as well. Then you cak remove the housing and look alt the cooling tower. Remove it and replace the small round seals and put everything togueter.
Good luck.
Offline vwsteve
  • Junior Member
Engine Leaking !
« Reply #4 on: September 04, 2007, 10:55:03 PM »
thanks guys i will give it a look this weekend... hopefullt thats the problem
