Author Topic: I Knew I Shoudlnt Have Gone Watercooled  (Read 2061 times)
Offline amishrabbi
« on: August 21, 2007, 02:20:38 PM »
bought an 83 gti to use as a DD.
first watercooled car ive owned, anyone want to guess what broke first? the radiator fan.
1963 Beetle, 2017cc Stroker
« Reply #1 on: August 21, 2007, 03:59:57 PM »
Should of bought a BMW :lol:
Offline amishrabbi
« Reply #2 on: August 21, 2007, 04:12:02 PM »
to much money :P
but seriously, ive checked every part of the circuit and replaced all of the parts that arent wires
still nothing
Offline shovel80
« Reply #3 on: August 21, 2007, 05:14:12 PM »
hook the fan up to direct power  Does it run ?
there should be a relay to start the fan and there is also a thermostat to tell the fan when to turn on
Offline shortseurocustom
« Reply #4 on: August 21, 2007, 05:16:53 PM »
Have you checked the fuse panel for corrosion? I've had many early watercooled cars and this seems to be a common killer in the electric dept... Before you toss any switches and relays, check that out! Don't downplay the water too much- early GTis and Rabbits are still an affordable kick-in-the-pants on curvy roads!
Good luck
« Last Edit: August 21, 2007, 05:17:33 PM by shortseurocustom »
If you want it bad, you'll get it bad- The worse you want it the worse it will be!
« Reply #5 on: August 21, 2007, 06:10:21 PM »
Good on ya!  Remember what I told you?  These things come in 3s.  We can't afford to lose another Beetle.  A Rabbit is expendable.
Offline amishrabbi
« Reply #6 on: August 21, 2007, 06:54:56 PM »
fan runs when jumped,i checked all the fuses ect out and replaced the relay and the switch, wires are all good so are connections. its at the shop now, i gave up.
great little car though, 83 gti with a 16v swap and suspension upgrades
« Reply #7 on: August 21, 2007, 06:59:24 PM »
Are you sure its getting hot enough to trigger the switch?
Offline amishrabbi
« Reply #8 on: August 21, 2007, 07:03:07 PM »
supposed to turn on at 87, hits 100 without turning it on
« Reply #9 on: August 21, 2007, 07:26:27 PM »
sender is probably toast
Offline amishrabbi
« Reply #10 on: August 21, 2007, 09:06:39 PM »
i replaced it, and the relay, and the in line fuse
i was out of ideas so its now at the shop. prob just be some tiny thing i overlooked
« Reply #11 on: August 21, 2007, 09:08:09 PM »
yup, I bet that's your problem, before switching to the aircooled world I owned 7-8 rabbits/ GTI's, could work on the ol' A1 blindfolded :ph34r:
Offline amishrabbi
« Reply #12 on: August 21, 2007, 09:11:54 PM »
well where are you when i need you :angry:
