Author Topic: What Clutch  (Read 6171 times)
Offline bufferman
What Clutch
« on: August 19, 2007, 11:23:22 PM »
what clutch do you guys reconmend for a street car in the past use to use 1700# kenndys the spring one never never had a problem guess now kennedy dosent reconmend them for my use the say use a stage 2 so any help would be great the car will see some track time its  82x90, 42x37 welded heads 48 IDA k-8 with 1-4 rockers
thanks steve
What Clutch
« Reply #1 on: August 20, 2007, 07:43:36 AM »
Stage 2 with a Daiken disc.
Offline G-dog
What Clutch
« Reply #2 on: August 20, 2007, 12:25:47 PM »
What James said.
Offline Rob DVKK
What Clutch
« Reply #3 on: August 20, 2007, 03:16:08 PM »
What James said.
Ditto.
Offline bufferman
What Clutch
« Reply #4 on: August 20, 2007, 10:19:21 PM »
thanks guys
Offline AlanU
What Clutch
« Reply #5 on: August 26, 2007, 08:32:24 AM »
I do like my copperhead disk.  I dont side step but the clutch does have \"give\" to soften the blow to the trans.
I'll try my daiken superdisc one of these days but my copperhead did give me a 1.51 60ft.
Offline bufferman
What Clutch
« Reply #6 on: August 27, 2007, 12:32:14 AM »
alan
is that with a stage II kenndy p/p
Offline AlanU
What Clutch
« Reply #7 on: August 27, 2007, 08:57:33 PM »
alan
Yup,
I do like the copperhead and it apparently has a less aggressive bite than a super daiken. You might consider either disk but sometimes you might want a slower 60ft if it saves your 1st gear from grenading.
Dont get me wrong but there are alot of big boys using the cheap daiken disk. Cost factor wise the super daiken is a great cheap disk. You can almost buy 3 daiken disks to 1 copperhead.
I'll try the daiken perhaps next year but my copperhead disk I'm using is about 5yrs old with aprox 15000km's on it.
What Clutch
« Reply #8 on: September 01, 2007, 01:42:29 PM »
would the daiken or copper head work for strictly a street car.
engine is a 2007 have no pressure plate or clutch yet.
probably will never see the track any recomendations??
Offline Darren Dilley
What Clutch
« Reply #9 on: September 01, 2007, 06:40:50 PM »
Russ i would think a stage two with a copperhead would give you the best of both worlds..  ;)
Offline GMB
What Clutch
« Reply #10 on: September 11, 2007, 02:31:18 PM »
The stock clutch and disc are good to 130 ft lbs torque.
« Last Edit: September 11, 2007, 02:31:35 PM by GMB »
Warrior sand rail:
2276cc 82x94
Single 40mm Kadron w/32vent
Equalizer 5lb pulley
Stock lifters
Stock aluminum pushrods
Offline bufferman
What Clutch
« Reply #11 on: September 12, 2007, 12:49:36 AM »
thanks again guys just got a stage two kenndey 3 finger found some new old stock stuff kinda like the old school stuff guess will have to see what happends
steve
