Author Topic: It's Alive!  (Read 2785 times)
It's Alive!
« on: August 07, 2007, 05:20:49 PM »
Well after sorting out a few minor glitches like a fuel leak and one of the IDA needle & seats sticking closed before we gave it ignition and started it, she roared to life on the 1st crank :rockon:  :rockon:  :rockon:  :rockon:  :rockon:  :rockon:  :rockon:  :rockon:
I couldn't sync the carbs yet cause I need to make an adapter for the monster velocity stacks for my snail meter but the father in law and I took it for the maiden blip up the street and holy mother farker i'm in love :wub:
I don't think I took it over 4500 rpm but a little puff on the throttle doing around 40km in second ( in a straight line none less) and we were quickly slideways without even trying, can't wait till the carbs are dialed in.
i'm gonna try and geta video clip up tomorrow :ph34r:
« Last Edit: August 07, 2007, 06:05:57 PM by josh »
It's Alive!
« Reply #1 on: August 07, 2007, 06:14:54 PM »
Way to go can't wait to see it this summer .Take er easy  :D
It's Alive!
« Reply #2 on: August 07, 2007, 06:48:06 PM »
the carbs are flooding when engine is shut down and hot :angry: you can here it boiling and look down the bore and they are dripping from the middle winged looking thing (aux vents?) on #1&3.
Who's the IDA whiz on here? I never saw this with my IDF's....... any tips?
It's Alive!
« Reply #3 on: August 07, 2007, 07:13:23 PM »
afaik, bruce tweddle knows his way around an ida pretty well.
way to go on the fire up josh. it must feel great. i'm sure you'll get the carb issues sorted and you'll soon be getting sideways more often. B)
It's Alive!
« Reply #4 on: August 07, 2007, 08:50:46 PM »
way to go.....what a good feeling :P
It's Alive!
« Reply #5 on: August 07, 2007, 08:52:57 PM »
I'll give bruce a try, thanks.
Hell ya it feels great to hear it run, and gettin' bent is one of my favorite passtimes :mullet: I am a Langford man and all!!
This dickhead neighbour down the street tried to give me shit about driving it on the street and it was all I had not to try out the line lock infront of his house after our shouting match :P
here's the money shot
Offline KOOL-AID MAN
It's Alive!
« Reply #6 on: August 07, 2007, 09:00:28 PM »
Very nice, And I'm loving the stinger  :rockon:
It's Alive!
« Reply #7 on: August 07, 2007, 09:04:19 PM »
She's a tad on the ear piercing side with no baffle, well more than a tad it's obnoxious but ill roll it for a while B)
It's Alive!
« Reply #8 on: August 07, 2007, 09:06:54 PM »
Lookin good Josh! Cant wait to see it in person. :rockon:
Offline vanBoven
It's Alive!
« Reply #9 on: August 07, 2007, 09:55:54 PM »
never thought of using a screwdriver as a hood prop, good idea! engine looks sweet by the way B)
Offline Greg
It's Alive!
« Reply #10 on: August 07, 2007, 10:00:45 PM »
That thing is gnarly!
Cant wait to see it ripping around the streets of vic!
It's Alive!
« Reply #11 on: August 07, 2007, 10:50:11 PM »
yeah just wait till Ross gets back to work Greg, he'll tell ya all about his white knuckle ride ;)
Offline AlanU
It's Alive!
« Reply #12 on: August 08, 2007, 08:21:24 AM »
Josh,
Just remember theres a noise restriction on cars at Mission raceway on street night drags. You better put  a muffler on your racecar  ;)
If you go to the test and tunes theres no issues using a stinger.
Contact Mr. Tweddle since he's probably the IDA expert in Western Canada if not even East.
It's Alive!
« Reply #13 on: August 08, 2007, 01:08:19 PM »
Well that would of sucked, showing up friday night and getting shut down....I had no clue :wacko: Will I qualify if I cram a baffle in it?
Anyone got a merged muffler they wanna lend me for that night? I'm a broke ass and can't afford one right now.
Mr Tweddle has helped me out, thanks
« Last Edit: August 08, 2007, 01:09:27 PM by josh »
Offline amishrabbi
It's Alive!
« Reply #14 on: August 08, 2007, 01:29:51 PM »
if i buy back the beetle you can use the one off that for the night if it will work
and if the engine hasnt been transplanted
1963 Beetle, 2017cc Stroker
Offline flat4
It's Alive!
« Reply #15 on: August 08, 2007, 01:30:11 PM »
Is it a small 3 bolt flange? I can bring my extra muffler with me if it is.
Water is for ducks
1975 Super Phat Chick
Sand Rail Project
It's Alive!
« Reply #16 on: August 08, 2007, 01:53:38 PM »
Thanks brendon, I know that one fits cause I use to run this header on that car, when will you know if you are getting it back?
Flat 4, could you measure the bolt pattern for me? I don't know what size I have, it's a 1 3/4\" S&S header. If it's the same, that would be killer!!!
Offline jeff lovell
It's Alive!
« Reply #17 on: August 08, 2007, 02:43:31 PM »
Josh your car kicks major ass !!!!! :rockon:  :rockon:
You might need to get rid of some of that rubber fuel line, that won't fly at tech.  unless that is some of that new nhra aproved nylon fiber hose , but i still would not use it for the sake of a tech disagreement issue. Hot engine big IDA's hold the gas to the floor and crank it over till it fires up, It will start right up.
Offline jeff lovell
It's Alive!
« Reply #18 on: August 08, 2007, 02:46:09 PM »
take a roll of masking tape and wrap the sync tool until you have the sized correctly.
Offline Greg
It's Alive!
« Reply #19 on: August 08, 2007, 04:23:42 PM »
Hey josh I have a phat boy you can borrow if you want.
It's Alive!
« Reply #20 on: August 08, 2007, 04:40:15 PM »
thanks jeff, the previous owner (some dude in Oregon) left me with a pretty decent platform to build off of :P
Rubber fuel line.......what rubber fuel line? The lines off the regulator are the same ones that were on the car, I just put some black shrink wrap over the stainless braid, cause it looked stupid with the ss running beside the black aeroquip breathers.
good tip on the sync tool, I was gonna make up some fancy aluminum o-ringed adapter on the lathe, but your meathod sounds a little quicker ;)
Offline amishrabbi
It's Alive!
« Reply #21 on: August 08, 2007, 10:18:19 PM »
icbc gets the car friday, and after that it depends how long they dick around trying to lowball me, which im taking none of
i dont think josh believes in rubber fuel line, after what he did on my engine id be surprised to see rubber anything on this car.
It's Alive!
« Reply #22 on: August 08, 2007, 11:49:34 PM »
there are a few things that cause this.
first if your car is lowered in the frt a fair amount ,the fuel level in the float bowl will be higher at #1,3 and lower at #2,4.if combine this with a misajusted or high float level this can be the cause as well if you add a leaky needle and seat fuel will just pour out .check the float hight ,leaky needle and seats and if these are ok and it is due to a big rake then drop your float level 1mm.a good test is when you heavy break or decel down hill if your motor starts to die more than normal because of fuel dumping into #1,3 lower the float height.
you have a data loger you can map this.
myself,i run at 1.5 mm float height and for street use hook up my fuel pressure regulator to my advance vaccum port on the carbs .
also shut your electric pump off before you pull into the driveway etc and dump the pressure in the system and use some of the fuel in the lines and bowl,agan watch your data loger when your a/f ratio starts to lean out shut it down
It's Alive!
« Reply #23 on: August 09, 2007, 12:11:13 AM »
Hey I never thought of that one Jim, the car does have a fair amount of rake to it. I'll add that to the list. Bruce is helping me sort through this little stumbling block.
I'll try the pump kill trick and watch the LM1 too. I think flying a plane is easier than driving this car :o That's fie by me tho, it'll keep the riff raff from getting behind the wheel :P
« Last Edit: August 09, 2007, 12:15:28 AM by josh »
