Author Topic: Clutch Recommendations  (Read 4694 times)
Offline flat4
« on: August 01, 2007, 08:53:42 AM »
I finally pulled my engine last night to find out what was causing the vibration when I pressed the clutch petal. It turns out that the clutch engaging surface has been ripped away from the disk itself. It came out in about 6 pieces.
So what do you folks recommend I run for a disk?  I'm running a 2332 with a stage 2 kennedy.  What set ups do you have success with?
« Last Edit: August 01, 2007, 08:54:40 AM by flat4 »
Water is for ducks
1975 Super Phat Chick
Sand Rail Project
« Reply #1 on: August 01, 2007, 09:31:22 AM »
I use a stage two with a daiken disc, slips just enough to be safe :) While it's out check the mating surface of the flywheel and pressure plate to make sure they are flat - i've seen many that aren't lately.
« Last Edit: August 01, 2007, 09:32:15 AM by James Buchan »
Offline AlanU
« Reply #2 on: August 01, 2007, 09:22:01 PM »
look at the pressure plate and see if theres 4 hot spots. The shoe's do tend to go \"cone\" shaped with some miles.
There are some  high horsepower vdubs with super daikens.
« Reply #3 on: August 02, 2007, 11:31:37 AM »
The ACE copperhead would probably work quite well for you.
Or he could try the Black magic disc...eh Alan. ;)  :lol:
Offline AlanU
« Reply #4 on: August 06, 2007, 10:03:29 AM »
Trevor, Your mean!!!!!! :D
Ace copper is what I'm using right now and I also have a daiken superdisc in my parts whore stash.
Offline Alp
« Reply #5 on: August 06, 2007, 05:57:58 PM »
is that \"clutch PETAL\" similar to a dandelion petal Alan?   Maybe that's where your problem started.....
