Author Topic: Axle Thread  (Read 5504 times)
Axle Thread
« on: July 26, 2007, 09:24:12 AM »
Anybody know the size of the rear axle thread?? i forgot to measure and i wanted to order one?
or a good tip on first three dead threads and how to fix them??
Axle Thread
« Reply #1 on: July 26, 2007, 08:01:42 PM »
dead threads on the axle? or the nut?
Axle Thread
« Reply #2 on: July 28, 2007, 07:50:29 AM »
axle, and i am trying to find a die nut......im screwed......
« Last Edit: July 28, 2007, 07:51:13 AM by steveo_32 »
Axle Thread
« Reply #3 on: July 28, 2007, 12:33:04 PM »
goto
http://www.kbctools.com/can/main.cfm
and type in thread files
part no: 1-842-107
theres a metric thread restoring file that has the correct pitch for the axle thread (1.5)
these have worked in a pinch for me before, they arent great, but for 8 bucks you cant really go wrong....
i think ive seen them at princess auto aswell, but cant comment on their quality...... :)
Axle Thread
« Reply #4 on: July 28, 2007, 04:12:28 PM »
Good idea Dan.  I have a thread file I bought at KMS and it has worked well for many years.  A friend of mine has one from Snap-On and I noticed the tips are pointyer so it wll get deeper into the root of the thread.
Offline Ovalzealous
Axle Thread
« Reply #5 on: July 29, 2007, 09:58:03 PM »
M24 x 1.5
Go with the thread file if you can.
If you're really stuck, take an old axle nut, or preferably a skinnier nut of the same size, cut through it on one of the points. On the flat will work but not as well. Only cut through one side. Pry the nut wider until it fits over the axle threads and slide it on until it is on the other side of the damaged part. This is where the skinnier nut would be handy. Clamp it tight again and wind it off as usual. This should clean up the threads enough to use unless you really mangled them. If it starts to jam up just wind the nut on then off alternately.
Hope that helps some.
« Last Edit: July 29, 2007, 10:11:55 PM by Ovalzealous »
Axle Thread
« Reply #6 on: August 07, 2007, 11:48:36 AM »
ya, i had a thread file but i ended up just using a single swiss file and filling thread by thread!
nut is on and going strong!!
