Author Topic: Happy Happy Joy Joy  (Read 2187 times)
Offline 66split
Happy Happy Joy Joy
« on: February 13, 2004, 09:25:25 AM »
ok here is the digs..my motor (1776, FF, 8 doweled) is makin a racket.  I tear it down..findings:
- cam gear and main crank gear are both chipped something nasty
I can deal with that...
-  cam gear is loose, i can remove the bolts with my fingers and there are no washers (supposed to be?)
-  the rear main bearing saddle is grooved, will need line bore
-  i remove the main bearing and it is stamped .050
dammit!!!!!!!!  I guess the good news is that the pistons/liners and crank/rod assembly is good and the pistons are balanced...oh..and i have a new aluminum case that is not machined...dammit again! At least i will get a seat in the suite at the canucks game tonight...center ice baby..
« Last Edit: February 13, 2004, 09:27:04 AM by 66split »
Happy Happy Joy Joy
« Reply #1 on: February 13, 2004, 09:37:51 AM »
Good news  :(
are you doing to open up the AL case for a larger crank?  while you have everything apart?
stephan :rockon:
« Last Edit: February 13, 2004, 09:38:31 AM by Stephan Schmidt »
Offline 66split
Happy Happy Joy Joy
« Reply #2 on: February 13, 2004, 09:54:44 AM »
i think i am going to take one of those short blocks off of Geoff....and move what I can over.  The top end is still good, but I would like to go to new heads as well....
Happy Happy Joy Joy
« Reply #3 on: February 13, 2004, 09:56:23 AM »
good idea.  those short blocks are new and aren't very pricey.  I'd add in a mild cam and such.
Stephan
