Author Topic: Bleeding Fuel Lines?  (Read 4563 times)
Offline kombikruiser
« on: February 11, 2004, 11:08:55 PM »
79 FI 2.0. girlfriend ran it out of gas on the alex fraser bridge; now it falls on its face when you need to accelerate, ie: on the highway, accelerating after  a corner.
If you feather it it comes back, but you gotta be gentle.
i dont like gentle.
i want my old van back.
are the lines pressurized after the pump? what steps do i take to bleed the system? i know about the screw on the metal line (7mm) in the engine compartment. when do i get to turn it?
would someone care to enlighten me?
'57 Type 1
'67 Type 1
'66 Type 2
'67 Type 3 Fastback
« Reply #1 on: February 12, 2004, 08:44:13 PM »
I don't think you need to bleed it. I've run out of gas a few times with  F.I. and never had a problem.  I wonder if you may have stired up something from the bottom of the tank . Might be time to check the screen in the tank and a new filter aswell . Could also turn out to be some thing totaly unrelated to this incident , points , vacume hoses, etc.  Hope this helps.
btw , that 7mm srcrew is for testing fuel presure.( remove it , hook up gage, run motor, check presure)
« Last Edit: February 12, 2004, 08:48:12 PM by Hansk »
« Reply #2 on: February 13, 2004, 06:36:14 PM »
thanks hans.
i just wanted to be clear on that issue. i'm gonna move on tho points/condenser as the next culprit.
thanks for your reply
'57 Type 1
'67 Type 1
'66 Type 2
'67 Type 3 Fastback
« Reply #3 on: February 16, 2004, 06:15:52 PM »
heh heh...new fuel filter solved everything.
Suprizing tho, the old one was only a month old.
'57 Type 1
'67 Type 1
'66 Type 2
'67 Type 3 Fastback
