Author Topic: Missing Irs Drum Spacer ?  (Read 1554 times)
Offline shovel80
« on: June 04, 2007, 04:11:31 PM »
I just converted from swing axle to IRS in the 68 type1 when I put the drum on and tourqued it down the drum did not tighten up is there a spacer that goes between the nut and drum that I am missing or a spacer between the drum and outer axle bearing ??
Thanks Dave
« Reply #1 on: June 04, 2007, 04:24:27 PM »
There is indeed a spacer that goes between the outer roller bearing and the drum.  IIRC it is about 12-13mm thick with a bevel on the OD of one end.
Offline shovel80
« Reply #2 on: June 04, 2007, 08:05:57 PM »
will the outer spacers from my swing axle work for the irs ??
if not does anybody have a set they want to part with
Thanks Dave
« Reply #3 on: June 04, 2007, 08:56:24 PM »
I believe they will, maybe just double check the fit inside the seal.
« Reply #4 on: June 05, 2007, 12:30:08 PM »
No, the swing axle spacer is wider.  None of the swing axle spacers are right for IRS.
Offline shovel80
« Reply #5 on: June 23, 2007, 06:37:39 AM »
Ok finally got the time to take apart the axles and check the spacers.
The inner spacer is 15.9 mm x 37.5 mm the middle spacer is 56.8 mm x 38 mm the outer spacer is 11.9mm x 44.4 mm.
There was no inner oil seal in the setup
and I found some thin rings of metal from ihe inboard side one was still attached to the stub. I do not know what they are from old seal, One has an on OD of 64 mm aprox and he other is 80 mm OD
Is the inner oil seal the same as the outer one if so my inner spacer should have the same od as the outer one to seal?
Thanks Dave
« Reply #6 on: June 23, 2007, 01:19:35 PM »
Dave, see my reply on the big site.
If you want, I can bring some original spacers to the show on Sunday.
Offline shovel80
« Reply #7 on: June 24, 2007, 12:48:36 AM »
So If I get this right
these 2 peices
form this
and I am still missing a spacer htat is the same as the outer one
if so thanks to all
Dave
\"any body going to the show and then back through kamloops  ??\"
