Author Topic: Engine Operating Specifics  (Read 3559 times)
Offline Milkman
« on: May 20, 2007, 03:41:50 PM »
Well we took the '66 out for the 1st long drive of the season this weekend. I just wanted some opinions based on the gauge readings. For one thing, the RPM seems a little high to me...
Here are the specs:
1966 Beetle
1600cc
Dual 34 ICT's
019 Distributor with pertronixs
4.37 Ring & pinion tranny
165/70R15 tires (Is that stock size or close to it?)
What the gauges read today:
Ambient outside temperature: 22c
Speed: 100kph
RPM: 3400
Cylinder head temp: 370F (That seems high to me)
Oil temperature: 190F
Oil pressure: 35PSI
Sustained speed of 100KPH for about an hour there & an hour back. Does everything seem to be reading within the correct ranges? CHT & RPM both seem high to me.
Greg
« Reply #1 on: May 20, 2007, 05:03:12 PM »
Here are the specs:
1966 Beetle
1600cc
Dual 34 ICT's
Speed: 100kph
RPM: 3400
Oil pressure: 35PSI
Greg
I am not an expert.
That rpm at 100KPH does not sound too bad with that trany and those tires. However, I think with that trany you would rev higher than a 4:12 and I think stock tires are 165 80 15 and they stand at 25.39\" so yours are probably a bit smaller.
As for the Cylinder heads temperature, I think they are hot at 370F and it seems to me that I read some literature about it and 250f-290f comes to mind.
I am sure that you will get more informative feedback from other guys soon.
« Last Edit: May 20, 2007, 05:04:55 PM by egspot »
Offline Milkman
« Reply #2 on: May 20, 2007, 05:56:13 PM »
Would it be souly the higher RPM that is making the heads hot? All the engine tin is in place, all the engine compartment seals are new & I'm running the correct fan for the doghouse set up. I thought that was kind of hot for CHT...
« Reply #3 on: May 20, 2007, 08:28:32 PM »
What do the cht's do when you come to a stop or around  town or if you accelerate hard?
If they only creep up like that at those steady speeds I'd wonder if it may be a bit lean.
I remember my cht's would jump up and down . eg -hard accelerating + 30f ,  deccelerate - 30f ,  average - aprox 300f     (something like this)
Offline Milkman
« Reply #4 on: May 20, 2007, 09:42:06 PM »
When I'm stopped or idling the CHT gauge sits around 250-275. When accelerating hard it goes up to around 400-420.  I'm pretty sure I'm not running lean, but I can't remember what jets I have in the carbs.
One thing I did notice tonight with the engine cold though. As soon as I turn on the key the CHT gauge is already at about 125-150F. Is it possible that I could have a bad gauge? Out of calibration?
« Last Edit: May 20, 2007, 09:42:49 PM by Milkman »
« Reply #5 on: May 20, 2007, 11:05:35 PM »
what type of sender is it?
Offline Cameron
« Reply #6 on: May 21, 2007, 11:12:11 AM »
I would suggest that you double check your ignition timing. Also, make sure the distributor is advancing correctly.
Think it's lean? What do your spark plugs say?
Offline Milkman
« Reply #7 on: May 21, 2007, 11:15:02 AM »
VDO brand. The type that goes where the #3 spark plug washer should be.
Offline Milkman
« Reply #8 on: May 21, 2007, 11:17:21 AM »
Timing is set at 30 degress total advance at around 3000 RPM, advances nice & smooth too. At last check (about 3 weeks ago) the spark plugs were a nice tan color.
Everything seems ok, I think maybe I have a CHT Gauge that is not very acurate.
« Reply #9 on: May 21, 2007, 12:33:05 PM »
Do you have an infrared temp gun to try?
Point it at the bottom of cyls # 3 & 4, and compare it to the gauge to see if it's out of wack.
Offline Milkman
« Reply #10 on: May 22, 2007, 07:15:36 PM »
I'll take an infared gun with me to FarFrumHome this weekend & see where the head temperatures are really at. Thanks for the tip!
