Author Topic: Convert Irs To Wide 5 Drums  (Read 5045 times)
Offline flat4
« on: May 13, 2007, 07:56:05 AM »
I'm looking to swap a ball joint/IRS pan to wide 5.  I have a wide 5 disc brake kit for the front, but am wondering what works in the rear.  I do have a pair of type 3 later rear wide 5 drums, but don't know if they will work, what mods need to be done, shoes, cylinders, and all that jazz.
Anyone?
Water is for ducks
1975 Super Phat Chick
Sand Rail Project
« Reply #1 on: May 13, 2007, 08:47:54 AM »
Just find any later type 3 rear backing plates (with e brake levers etc.)  Then pick up some new type 3 shoes and cylinders from ACVW or.....
« Last Edit: May 13, 2007, 08:48:47 AM by Hansk »
Offline westcoast-paul
Re: Convert Irs To Wide 5 Drums
« Reply #2 on: June 06, 2008, 01:40:39 PM »
back from the dead - but i couldn't help myself...
good luck finding the backing plates.
easiest - use 1966-67 front and rear brakes.  cut off 12mm off the 4 lug drum nipple and use it as a spacer.
Offline GMB
« Reply #3 on: August 29, 2008, 04:04:31 PM »
Hey Freddy I have a conversion drum hot out of the sand box gimme a call.
    Gary.
Warrior sand rail:
2276cc 82x94
Single 40mm Kadron w/32vent
Equalizer 5lb pulley
Stock lifters
Stock aluminum pushrods
