here's what i did before i took my 64 w/ 1600dp through....
adjusted valves, adjusted points, changed the plugs, changed the oil, adjusted the carb, filled gas tank 1/2 full, put some wynns fuel additive in the tank, took it for a nice 20 minute hard drive on sw marine drive, pulled over & revved the motor while spraying carb cleaner down the throat of the carb, went for another hard drive for 15 minutes, never turned the car off while i waited in line....and passed w/ some pretty good numbers (allthough i was above average on idle co).
good luck. B)
