Author Topic: Help?  (Read 4589 times)
Offline 66vdub
Help?
« on: May 06, 2007, 10:08:12 AM »
hey guys, i got a question... i pulled my motor not to long ago and pulled the wires on the voltage regulator and now i cant figure out wich ones go where. im just wonderin if ne one knows if there is a diagram for it or give me a few tips. thanks guys for the help
Offline surgerypending
Help?
« Reply #1 on: May 06, 2007, 10:23:12 AM »
Try this http://www.vintagebus.com/   tons of wiring diagrams here. hope you find what your looking for!
Help?
« Reply #2 on: May 06, 2007, 10:23:27 AM »
here's a wiring diagram for a us spec 67 w/ regulator...
http://www.thesamba.com/vw/archives/info/w...ring/bug_67.jpg
and the legend for that diagram...
http://www.thesamba.com/vw/archives/info/w..._67_USA_key.jpg
(once you've clicked the link, you can click on the pictures to make them bigger).
good luck.
Help?
« Reply #3 on: May 06, 2007, 10:50:16 AM »
Try this.
You want to use the before diagram.
http://www.airspeedparts.com/tech/alternat..._conversion.htm
Hope that helps
« Last Edit: May 06, 2007, 11:03:06 AM by egspot »
Offline 66vdub
Help?
« Reply #4 on: May 06, 2007, 11:09:48 AM »
thanks guys soo much for ur help im wonderin since its been 12 volt converted do these diagrams still work? i guess i should have mentioned that sorry
Help?
« Reply #5 on: May 06, 2007, 11:22:23 AM »
My pictures are from a 1966 converted to 12V (regulator) and a Show car with a generator 12V.
The diagrams on Airspeed are both settings 12V alternator and 12V  alternator. If your wiring still there it should work the same.
My 1966 pictures.
« Last Edit: May 06, 2007, 11:32:42 AM by egspot »
