VW Club Corner
94mm Cylinders That Fit A 92mm Case?
Topic: 94mm Cylinders That Fit A 92mm Case? (Read 4195 times)
egspot
March 26, 2007, 12:15:33 PM »
Add:
Brand new mahle 94mm B pistons balanced & lightend with rings and new autocraft 94mm cylinders sleved to fit 92mm case.
My Questions:
Your add does not make sense to me and I would like to get more specifics. Here is a few questions:
The cylinders fit a case opened/bore to fit 92mm/90.5mm? Or do they fit a case opened/bore to fit 94mm?
Another possibility is that they are 92mm pistons and cylinders but the cylinders are the thick cool ones that fit a case opened for 94mm cylinders? [_[
His Answer:
They are 94mm cylinders and had them machined to fit 90.5/92mm case, not the thick wall cylinders that work with 94mm case and can use 92mm pistons.
Any one ever heard of this and why would anyone do this?[/
Last Edit: March 26, 2007, 12:19:33 PM by egspot
http://www.cardomain.com/ride/2142087
James Buchan
March 26, 2007, 01:23:14 PM »
Simple:
You don't need to open your case to upgrade to a 94 - just cut your heads. Lots of people use them, they work.
VW Club Corner
