Author Topic: Narrowing Rear Ends  (Read 1704 times)
Offline Brassmonkey
Narrowing Rear Ends
« on: March 23, 2007, 09:36:50 PM »
any body done this need help, anything to look out for or how to help!
Narrowing Rear Ends
« Reply #1 on: March 23, 2007, 11:47:51 PM »
IRS or Swingaxle?
Offline Brassmonkey
Narrowing Rear Ends
« Reply #2 on: March 24, 2007, 07:31:45 AM »
sorry, yeah its a swing I have the axels already and all the suspension parts I just want to narrow the rear end now.
« Last Edit: March 24, 2007, 07:32:15 AM by Brassmonkey »
Narrowing Rear Ends
« Reply #3 on: March 24, 2007, 08:04:51 AM »
What do you mean by narrow? Do you mean changing from long axle to short?
Offline Brassmonkey
Narrowing Rear Ends
« Reply #4 on: March 24, 2007, 08:10:45 AM »
ok I have 3 inch narrow folts axels for my bus tranny and I want to narrow the torsion tube so I can bolt the rear end in.
Narrowing Rear Ends
« Reply #5 on: March 24, 2007, 09:55:18 AM »
Well I would say cut and narrow the torsion tube 3\" per side, bevel the tubes and weld it back up. I would probably put a sleeve (piece of pipe with the similiar o.d. as the i.d. of the torsion tube) in there as a sort of backing plate to get \"maximum penetration\"  :rockon: when welding it back together. I would also clamp on a piece of angle or channel to make sure the tubes are straight when I tack it together. Leave it tacked and mock up the suspension before welding. Measure twice. Weld once. I take it you have the springplates with the longer spline  tube and the 21 3/4\" torsion bars. Disclaimer : Keep in mind I have not done this before but have researched it for a future project so you might want another opinion or suggestions. Let us know how it goes. By the way, where is Rosedale, B.C.?
Good luck
Jeremy
Offline Brassmonkey
Narrowing Rear Ends
« Reply #6 on: March 24, 2007, 10:18:20 PM »
ITS ITS NARROWED and I love it and Rosedale is just outside chilliwack if that helps.
« Last Edit: March 24, 2007, 11:23:45 PM by Brassmonkey »
Narrowing Rear Ends
« Reply #7 on: March 25, 2007, 10:35:20 AM »
That didn't take very long. I take it it went pretty smoothly. Do you have any pics?
Jeremy
