Author Topic: New To Vw's  (Read 1217 times)
Offline oldschooljay
New To Vw's
« on: March 22, 2007, 05:40:52 PM »
hey guys, names Jay and i'm from vic. just bought the 67 bug off here that needs a motor and transaxle.
aside from getting that put back in, how can i lower it a tonne ona  budget. i need it to be low low and noce wheels. what do oyu guys suggest?
i also have my daily driver project on teh go. it is  a55 pontiac that is a blast to drive. i am looking for ward to the bug build.
any good ideas or suggestions or pics of some nice 67 stle bugs would help.
thanks
J
New To Vw's
« Reply #1 on: March 22, 2007, 07:32:16 PM »
Hey know you from the flat black board check out our gallery and tech sections .You can also try THE SAMBA just google it tonnes of info and how twos as well as gallery good luck  :)
New To Vw's
« Reply #2 on: March 22, 2007, 07:43:46 PM »
welcome jay.
i recommend you do alot of research and spend as much time reading as possible. purchase a bentley manual for your car and even grab the john muir idiots guide to vw repair (it's pretty lo-fi, but it comes in handy every once & awhile). there are also a ton of technical threads on this forum and on http://www.thesamba.com
there is also a gallery on thesamba.com where you will find lots of pics of acvw's with different wheel & height combinations.
as per lowering, i say do it the right way. for the front you can start with drop spindles and/or an adjustable beam. for the back you can turn the springplates on the splines. it's not too difficult, but it does take a little time, money & patience.
there are alot of other things to consider too. tire to car clearance, narrowed beams (with narrowed tierods & leafs), wheel width & offset, size of front & rear tires, using caster shims, replacing springplate bushings, (*edit*sorry, i was thinking of a king & link front end*), new balljoints....
« Last Edit: March 22, 2007, 07:47:29 PM by silas »
New To Vw's
« Reply #3 on: March 22, 2007, 08:51:53 PM »
thanks, i have been lurkin at the samba and volksrods for a while. just nice to see some pics if people go tthem. ya know?
