Author Topic: Best Gas For Air-cooled  (Read 7228 times)
Offline Rocco_Buehler
    • OKVW - Okanagan's VAG Scene
« on: March 19, 2007, 01:06:18 PM »
pretty self explanatory....have a '76 2.OL EFI air-cooled and wondering what i should be putting in there to keep it running long time and not spend a fortune
« Reply #1 on: March 19, 2007, 01:44:38 PM »
regular unleaded will work just fine
« Reply #2 on: March 19, 2007, 11:33:53 PM »
Not DVKK but there is usually a sticker on the gas door (was on my 75 westy) that says what octane you should put in (can't remember what octane they usually say but it was mid grade I think). I wouldn't personally use regular. It does make a big difference in operating temperature when you are travelling. I always treat our VW's to the best though. Aren't they worth it?
« Reply #3 on: March 19, 2007, 11:46:49 PM »
checked the stickers they are selling at Wolfsburg west and it states regular gas 91 minimum octane
http://www.wolfsburgwest.com/cart/DetailsL...t.cfm?ID=ZVW30A
This ones a little more readable but for beetles
http://www.wolfsburgwest.com/cart/DetailsL...st.cfm?ID=ZVW30
« Last Edit: March 19, 2007, 11:48:14 PM by vwboop »
« Reply #4 on: March 20, 2007, 12:08:03 AM »
i was taught to use the lowest octane you can run that wont knock/ping.
anything greater and you're wasting your money.
example...if it knocks with 87 and doesnt with 89, there is no need to use 91.
Offline 68IIIbuggy
« Reply #5 on: March 20, 2007, 05:22:32 PM »
All aircooled VWs were designed to run regular gasoline. AFAIK, the octane rating system used when your car was new is different than the one used today, so 91 on the sticker corresponds to the 87 regular available at the pump today. As long as your compression is stock, you can run 87.
« Reply #6 on: March 20, 2007, 09:11:37 PM »
thanks alot guys...i'm sure i'll be up here with more questions as I work on my new baby more
« Last Edit: March 20, 2007, 09:11:47 PM by Rocco_Buehler »
« Reply #7 on: March 20, 2007, 10:20:44 PM »
the sticker also says 91 RON (research octane number).
i'm pretty sure the gas in the pumps here in bc is RON+MON/2.
« Reply #8 on: March 20, 2007, 10:32:04 PM »
just convert it to bio-diesel.........or propane, I hear its on the comeback... :P
Offline AirCooledRules
« Reply #9 on: April 14, 2007, 02:51:06 PM »
91 RON (european grading system of fuel) is equivilent to 87 OCT.  Anything more then your car requires is wastning money, High octane gas is for high compression engines.
1960 Volkswagen Beetle
1975 Honda CB125S
1983 Audi UR-Quattro
1984 Volkswagen Rabbit GTI
1998 Audi A6
