Author Topic: New Parts Just In!  (Read 2053 times)
New Parts Just In!
« on: February 03, 2004, 02:29:19 PM »
These parts have just arrived today!
*Forged welded 82mm wedgemated crank and 12.5 flywheel.
*Forged welded 84mm wedgemated crank and 12.5 flywheel.
*Erco chromoly Pinion nut retainers (early & late)
*Erco gears
*Carrera 90/10 drag shocks for king pin and balljoint
Balljoint available for std height and for droped spindles
*Thin line deep sumps
*Dellorto/Weber oval port manifolds
*Race push rod tubes
*IDA linkage (hex bar)
*All new High roof Alum super case, ready for motors as large as 86x94 and bigger!
« Last Edit: February 03, 2004, 02:50:46 PM by Gkafer »
New Parts Just In!
« Reply #1 on: February 03, 2004, 02:34:49 PM »
what are they flywheels lightened to if at all?
New Parts Just In!
« Reply #2 on: February 03, 2004, 02:42:33 PM »
FYI - I bought a thin line sump a coulpe months back and they are real nice~!
New Parts Just In!
« Reply #3 on: February 03, 2004, 02:50:27 PM »
Flywheels are lightened to 12.5 lbs (standard light weight)
New Parts Just In!
« Reply #4 on: February 03, 2004, 04:15:49 PM »
Are these the Gears that I am gonna need????
I also bought a sump very nice
New Parts Just In!
« Reply #5 on: February 03, 2004, 05:45:47 PM »
We need to figure out what you need and then order them You will need the Electron beam welded gear/hub combo like you have in the rail.
